Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 11-16-2009, 03:33   #1 (permalink)
    Member: 412460
    Thanks Meter: 4
    TM717 unlock help!!!
    TM717 flash cid 53 version R1FCO11.please help unoock by setool2.thanks all
    The Following User Says Thank You to tomick For This Useful Post:
    Old 11-16-2009, 03:35   #2 (permalink)
    Member: 644210
    Thanks Meter: 74
    you can unlock it.. by setool3 with 1 log..
    Old 11-17-2009, 22:34   #3 (permalink)
    Member: 152547
    Sonork: 100.1586021
    Thanks Meter: 143
    u need 1log
    use latest setool version
    select i and 2 in the ttings tab
    choose jalou as the phone model in a2
    hold 2 + 5
    unlock.
    The Following 7 Users Say Thank You to akkay For This Useful Post:
    Old 12-01-2009, 23:08   #4 (permalink)
    Member: 823568
    Thanks Meter: 5
    btw . how much for 1 log?
    Old 12-11-2009, 07:54   #5 (permalink)
    faruk_gsm's Avatar
    Member: 877161
    Thanks Meter: 48
    Successfully Unlocked TM - 717
    u need 1log
    hold 2 + 5
    unlock.
    v0.915057/UNI
    CARD SERIAL: 00072XX
    Loaded 51 flash descriptors
    CFG:000000000000
    ChipID900,EMP protocol:0401
    BOOTROM MODE DETECTED
    OTP DBG: [1,53,1,35697903114329]
    OTP LOCKED:1 CID:53 PAF:1 IMEI:3569790311XXXXCERT:RED
    LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084
    LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084
    Model (from GDFS):TM717
    MAPP CXC article: R1FC011 prg1218-5230_TMOUS_ET
    MAPP CXC version: R1FC011
    Language Package: TMO-US
    CDA article: 1223-8973
    CDA version: R16A
    Default article: 1217-3366
    Default version: R1FC011
    PROVIDER: MULTIPLE
    Network LOCKED
    Elapsed: 25 secs.
    SIGNED MODE (USING SERVER)
    CFG:110000000000
    SERVER CREDITS LEFT/USED: 24/6
    CARD COUNTERS: FLASH 336, UNLOCK 97
    Elapsed: 3 secs.
    ALTERNATIVE SECURITY BYPASS ENABLED
    PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
    CFG:110000000000
    OTP DBG: [1,53,1,3569790311XXXX]
    OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903114329 CERT:RED
    GOT CHALLENGE
    GOT SEED:F2665DBA358073723590E91B
    GOT RESPONSE
    signoff response ok
    P96 AUTH PASSED
    DEVICE KEY:8B77ADA0CA4909B2BD7845590F38985A (0)
    RESTARTING...
    LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081
    LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081
    GOT CHALLENGE
    GOT SEED:40228161358073723590E91B
    GOT RESPONSE
    signoff response ok
    P96 AUTH PASSED
    RESETTING SECURITY TO FACTORY STATE...
    RESTARTING...
    OTP LOCKED:1 CID:53 PAF:1 IMEI:3569790311XXXX CERT:BROWN
    LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084
    LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084
    WRITING SEMCBOOT...
    PREPARING SECURITY...
    WRITING CLEAR SIMLOCK UNITS...
    ALL UNLOCK/LOCK CODES SET TO "71633310"
    CHANGING DOMAIN TO "CURRENT"
    SIGNING...
    DEVICE KEY RESTORED
    Unlock FINISHED
    Elapsed: 38 secs.
    The Following 3 Users Say Thank You to faruk_gsm For This Useful Post:
    Old 12-14-2009, 06:22   #6 (permalink)
    roney_nexus's Avatar
    Member: 288504
    Sonork: .:100.1587032:.
    Thanks Meter: 2,266
    u need 1log
    hold 2 + 5
    unlock.
    v0.915057/UNI
    CFG:000000000000
    CDA version: R16A
    PROVIDER: MULTIPLE
    Network LOCKED
    Elapsed: 25 secs.
    CFG:110000000000
    Elapsed: 3 secs.
    CFG:110000000000
    GOT CHALLENGE
    GOT RESPONSE
    signoff response ok
    P96 AUTH PASSED
    RESTARTING...
    GOT CHALLENGE
    GOT RESPONSE
    signoff response ok
    P96 AUTH PASSED
    RESTARTING...
    WRITING SEMCBOOT...
    SIGNING...
    DEVICE KEY RESTORED
    Unlock FINISHED
    Elapsed: 38 secs.
    nice posting log very thx bro.....
    The Following User Says Thank You to roney_nexus For This Useful Post:
    Old 01-06-2010, 14:30   #7 (permalink)
    Member: 629694
    Thanks Meter: 50
    bro which model to select
    Old 01-06-2010, 17:12   #8 (permalink)
    Cheater -Don't Deal with him-
    Member: 443336
    Thanks Meter: 21
    successfully unlocked tm - 717
    u need 1log
    hold 2 + 5
    unlock.
    V0.915057/uni
    card serial: 00072xx
    loaded 51 flash descriptors
    cfg:000000000000
    chipid:d900,emp protocol:0401
    bootrom mode detected
    otp dbg: [1,53,1,35697903114329]
    otp locked:1 cid:53 paf:1 imei:3569790311xxxxcert:red
    ldr:2009-07-31 10:42 1207-6250_db3200_cs_loader_acc_sdram_r2a084
    ldr:2009-07-31 10:44 1207-6251_db3200_cs_loader_app_sdram_r2a084
    model (from gdfs):tm717
    mapp cxc article: R1fc011 prg1218-5230_tmous_et
    mapp cxc version: R1fc011
    language package: Tmo-us
    cda article: 1223-8973
    cda version: R16a
    default article: 1217-3366
    default version: R1fc011
    provider: Multiple
    network locked
    elapsed: 25 secs.
    Signed mode (using server)
    cfg:110000000000
    server credits left/used: 24/6
    card counters: Flash 336, unlock 97
    elapsed: 3 secs.
    alternative security bypass enabled
    please connect phone in emp bootrom mode (hold "2+5")
    cfg:110000000000
    otp dbg: [1,53,1,3569790311xxxx]
    otp locked:1 cid:53 paf:1 imei:35697903114329 cert:red
    got challenge
    got seed:f2665dba358073723590e91b
    got response
    signoff response ok
    p96 auth passed
    device key:8b77ada0ca4909b2bd7845590f38985a (0)
    restarting...
    Chipid:d900,emp protocol:0401
    ldr:2009-04-21 18:27 1207-6247_db3200_reset_loader_acc_sdram_r2a081
    ldr:2009-04-21 18:28 1207-6248_db3200_reset_loader_app_sdram_r2a081
    got challenge
    got seed:40228161358073723590e91b
    got response
    signoff response ok
    p96 auth passed
    resetting security to factory state...
    Restarting...
    otp locked:1 cid:53 paf:1 imei:3569790311xxxx cert:brown
    ldr:2009-07-31 10:49 1207-6245_db3200_production_loader_acc_sdram_r2a084
    ldr:2009-07-31 10:50 1207-6246_db3200_production_loader_app_sdram_r2a084
    writing semcboot...
    Preparing security...
    Writing clear simlock units...
    All unlock/lock codes set to "71633310"
    changing domain to "current"
    signing...
    Device key restored
    unlock finished
    elapsed: 38 secs.
    wich model all say error bad hdr block not accepted
    Old 01-12-2010, 17:11   #9 (permalink)
    Member: 258525
    Thanks Meter: 44
    tm717 unlock
    i have tested 100%............ Working
    Thanks
    The Following User Says Thank You to newtouch For This Useful Post:
    Old 01-16-2010, 11:45   #10 (permalink)
    *shohel*'s Avatar
    Member: 537394
    Thanks Meter: 19
    Arrow TM717 unlock successfully
    cruiser can unlock TM717 successfully
    here logs ........
    Old 01-16-2010, 11:56   #11 (permalink)
    *shohel*'s Avatar
    Member: 537394
    Thanks Meter: 19
    TM717 unlocck successfully
    tm 717 unlock done
    ......................here log..
    ....http://img69.imageshack.us/img69/1405/cruiser.png
    Old 01-22-2010, 12:55   #12 (permalink)
    mkhan's Avatar
    Member: 178659
    Thanks Meter: 46
    i was unlocking tm 717 and it got dead can any 1 help me
    i need complete files of tm 717 urgentt
    help plzzzzzzz
    Old 01-22-2010, 13:09   #13 (permalink)
    Member: 841640
    Thanks Meter: 86
    help plzzzzzzz
    Just follow instruction in post #3, your problem will be solve..... I had same problem and solve it that way
    Old 01-22-2010, 14:51   #14 (permalink)
    mkhan's Avatar
    Member: 178659
    Thanks Meter: 46
    i have NO files
    which model files should i select
    Old 01-22-2010, 15:26   #15 (permalink)
    mkhan's Avatar
    Member: 178659
    Thanks Meter: 46
    anyone plz i need the flash files so i can restore my back to its real condition unlocking support is given on post 3 plz can any1 help
    am wating
    TM717 unlock drivers gophone SETool2 1 06-13-2010 16:56
    BlackBerry 8520 unlock help needed derk FuriousGold 3 04-08-2010 11:37
    iphone unlock help for bigners Mind Power iPhone 2 / iPhone 3G / iPhone 3GS 5 03-29-2010 17:05
    Tm717 unlock done baooshe2 Cruiser Suite 0 03-24-2010 10:49
    Page generated in 0.28733 seconds with 9 queries
