unlock problem with k800i in setool :eek:hi to all iface strange unlock problem in k800i from t-mobile ,,, here is log please seee them and give me suggestion ...when i unlock it, further procidure complite but last says rest file is bad can not flash it,,,i try many other rest file but same message comming.... SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101111011000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401902865 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM95 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 STARTING BOOTLOADER... INT LDR:DB2020_PRELOADER_FOR_SETOOL2 LDR:DB2020 LOADER FOR SETOOL2 FLASH ID: 2019 UPLOADING REST FILE "C:\Documents and Settings\WELCOME\Desktop\R1KG001_CXC1250210_GENERI C_WI.zip"... bad file, will not flash it. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 143 secs. |
follow this procedure on how unlock k800i brother open setools check signed mode in settings back to main click recovery go to empty refill tab put gdfs ssw format from your setools folder (note: use same cid) and click flash click clear now put again erom and then flash again now open the phone and it's unlock good luck brother |
thanks for help ,, i follow your instruction then post result |
thanks brother ..thank a lot:D |
