Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 06-07-2012, 09:13   #1 (permalink)
    Member: 321534
    unlock problem with k800i in setool
    hi to all
    iface strange unlock problem in k800i from t-mobile ,,,
    here is log please seee them and give me suggestion ...when i unlock it, further procidure complite but last says rest file is bad can not flash it,,,i try many other rest file but same message comming....
    SIGNED MODE (USING SERVER)
    PRELOADER SECURITY BYPASS ENABLED
    CFG:101111011000
    ChipID:9900,EMP protocol:0301
    PHONE STATE: "RETAIL"
    FLASH CID: 0052
    Speed:921600
    OTP: LOCKED:1 CID:51 PAF:1 IMEI:35570401902865 CERT:RED
    FLASH CID:52 COLOR:RED
    PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
    LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
    FLASH ID: 2019
    LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
    loader GDFS startup executed
    loader FILESYSTEM startup executed
    DISCONNECT PHONE NOW
    INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
    INSTALL PHONE MODEM DRIVERS IF NEEDED
    SEARCHING FOR PHONE, "STOP" TO ABORT
    PHONE FOUND AT COM95
    PHONE READY TO PROCEED
    EXECUTOR STARTED
    REMOVE CABLE FROM PHONE
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    FINALLY PRESS "READY"
    FLASH CID: 0052
    Speed:921600
    STARTING BOOTLOADER...
    INT LDRB2020_PRELOADER_FOR_SETOOL2
    LDRB2020 LOADER FOR SETOOL2
    FLASH ID: 2019
    UPLOADING REST FILE "C:\Documents and Settings\WELCOME\Desktop\R1KG001_CXC1250210_GENERI C_WI.zip"...
    bad file, will not flash it.
    USERCODE RESET TO "0000"
    Searching...
    Firmware SIMLOCK check determined.
    Unlock FINISHED
    Elapsed: 143 secs.
    Old 06-07-2012, 09:36   #2 (permalink)
    Member: 1438685
    follow this procedure on how unlock k800i brother
    open setools
    check signed mode in settings
    back to main
    click recovery
    go to empty refill tab
    put gdfs ssw format from your setools folder (note: use same cid)
    and click flash
    click clear now put again erom
    and then flash again
    now open the phone and it's unlock
    good luck brother
    Old 06-07-2012, 10:17   #3 (permalink)
    Member: 321534
    thanks for help ,, i follow your instruction then post result
    Old 06-07-2012, 12:46   #4 (permalink)
    Super Moderator
    THE CLASH's Avatar
    Member: 173077
    Sonork: 100.1594293
    open setools
    back to main
    click recovery
    and click flash
    good luck brother
    long winded way about things...
    Old 06-08-2012, 05:41   #5 (permalink)
    Member: 321534
    open setools
    back to main
    click recovery
    and click flash
    good luck brother
    it"s working ... handset unlocked successfully
    thanks brother ..thank a lot
    How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
    Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
    Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
    Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
    vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
    Page generated in 0.77262 seconds with 11 queries
