Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
08-23-2004, 15:48 | #1 (permalink) |
Junior Member Join Date: Jul 2004 Age: 57
Member: 74357 Status: Offline Thanks Meter: 0 | t610 flashing thanks riaz ahmed |
08-23-2004, 18:05 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | Hi riaz ahmed You need to download DIVLPT4 then get hold of the mcu flash files and the modem flash files *.arm and *.avr then you connect handset powered off to terminator select phone type then select flash files and click on "do selected jobs" then it should say bypassing boot authority then booting and then it will start flashing the handset PS use a fully charged battery WBR D. |
08-24-2004, 15:25 | #4 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Poland Age: 54
Member: 71669 Status: Offline Thanks Meter: 783 | service menu: just press >*<<*<* without card (< left joystik turn, > right joystick turn) and select Software information (or language information - sorry, i don't remember)... |
08-24-2004, 15:58 | #5 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ROMANIA Age: 46
Member: 55427 Status: Offline Thanks Meter: 7 | Take care with flashing t610 usually is not recomanded to downgrade. So take care what you put inside that phone. Here is all you need. You must register here but is free. http://www.cellular-support.com/nuke...name=Downloads regards |
08-25-2004, 15:39 | #7 (permalink) |
Member: 71669 Status: Offline Thanks Meter: 783 | maybe u try: - download DIV 3.1 oldschool (900/1800/1900 MHz version) or DIV LPT 4.0 - write flash (in DIV: Flash AVR CPU: ) e.g. T610_R6B004_xxx (xxx=EMEA1 or EU or AP or China) - write flash modem (in DIV: Flash ARM CPU: ) e.g. T610 R6B004 Modem Flash - write gdfs (in DIV: Write GDFS file: ) T610_Original_GDFS_area - Repair > Rebuild SP area using OTP IMEI flash (Main flash) & modem (Modem flash) & gdfs (Gdfs files): ics_igrec_zet "Take care with flashing t610 usually is not recomanded to downgrade. So take care what you put inside that phone. Here is all you need. You must register here but is free. http://www.cellular-support.com/nuk...?name=Downloads " |
08-25-2004, 15:53 | #8 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Spain Age: 42
Member: 30296 Status: Offline Thanks Meter: 8 | Hello Try this link http://www.ergilloflashes****/, and download the flashes for your phone and with divlpt v4 flash and unlock your phone. See you |
08-25-2004, 16:26 | #9 (permalink) |
Member: 74357 Status: Offline Thanks Meter: 0 | Dear Is there any need to remove RSA lock I am not sure either my phone has RSA protection or not. But it is only 3 month old. What do u think Looking for tips thanks for interests riaz ahmed |
08-25-2004, 16:40 | #10 (permalink) |
Member: 30296 Status: Offline Thanks Meter: 8 | Do this just press >*<<*<* without card The select Service Info,next SW info,if you hace R6Cxxx or R6Dxxx your phone have RSA protection and you need to do test point or kill RSA protection with on line logger.I recomend it http://www.faceoffmobiles.com/item--...--segoldserver Luck See you |
08-31-2004, 13:34 | #11 (permalink) |
Member: 74357 Status: Offline Thanks Meter: 0 | dead t610 and RSA unlocking Hi Guys As I have mentioned I cannot switch on my mobile phone T610. Can I still use RSA unlocker to remove RSA protection. My phone shows red light under joystick, but do not power on. Any tips riaz ahmed |
09-02-2004, 13:07 | #12 (permalink) | |
Member: 74357 Status: Offline Thanks Meter: 0 | Quote:
riaz ahmed | |
09-02-2004, 13:21 | #13 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Dreaming of Birdies! Age: 50
Member: 5587 Status: Offline Thanks Meter: 6 | Stupid question! but if you have red light on under joystick, is this when the unit is on charge? if so just leave on charge and the phone will eventually kick in. Had this problem many times with various S/E. Just a thought |
09-03-2004, 11:14 | #14 (permalink) | |
Member: 55427 Status: Offline Thanks Meter: 7 | Quote:
Best regards | |
T610 flash needs | MPhoneClinic | Sony Ericsson | 1 | 09-11-2003 14:52 |
Ericsson t610 flash file needed | Balkanvirus | Sony Ericsson | 0 | 08-09-2003 12:13 |
need T610 flash ??? | uni_gsm_tech | Sony Ericsson | 2 | 07-31-2003 16:02 |
T610 flash needed!!! | Winner58 | Sony Ericsson | 9 | 07-04-2003 14:00 |
t610 flash files urgenttttttttttttttttttttttt | Archie hawn | Wanted Products | 1 | 06-18-2003 15:25 |
