Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
12-20-2012, 09:50 | #1 (permalink) |
Insane Poster Join Date: Aug 2010
Member: 1360145 Status: Offline Thanks Meter: 12 | W300 error help So tried to flash it but i had no right cid file so i put it in recovery mode to change cid. Now phone is in developer mode and not on. Help me fix this PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35424401476645 CERT:BROWN FLASH CID:51 COLOR:BROWN setGDFS_params failed failed to setup GDFS Elapsed: 21 secs. PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35424401476645 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E writing "D:\Backup\Firmware\Sonyericssion\Flash files\GDFS\w300_gdfs\w300.ssw" CURRENT FLASH FILE CID:49 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 5 Will flash 5 blocks... subblock 000 NAK, [44140000/000080E8] Elapsed: 22 secs. I got this error while this steps that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. Provide solution... |
