Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 03-13-2007, 20:54   #1 (permalink)
    Member: 337124
    w550i ERROR: EROM (Boot) damaged with Cruiser/Recovery option!
    Hi friends...
    i have got a dead w550i>>i tried to flash it with cruiser with files of latest version...but sorry to say it did not complete flashing ...the main file ARM file was written upon well..the second file Raw FS was also written well...but when i customized the phone it asked again to remove RSA...
    Then i switched to USB-SMART....it gave an error message>>
    What should I do...i have a strong desire to learn more and share more and more...??
    anticipating a quick reply from masters in this field
    Old 03-13-2007, 21:10   #2 (permalink)
    Member: 9224
    why switched to USB-SMART? You could remove and then customized it with cruiser. what message you are getting now with cruiser? if boot is damaged then you can repair it by testpoint.
    Old 03-14-2007, 00:10   #3 (permalink)
    Super Moderator
    THE CLASH's Avatar
    Member: 173077
    Sonork: 100.1594293
    you struggling because this is a cid 49 phone , thus the filesystem must be flashed first, and customise it, before you flash the main (ARM).
    lets start again useing cruiser.
    select model.
    Remove RSA, now if need be , go to flash tab and repair erom..(if possible)
    Direct unlock..
    Flash File system, and customise fs, from drop menu select same as ur files.
    now flash the main (arm)..
    remove battery and replace (without sim card) switch on, let it finish with please wait screen, then you can add sim..
    fially put usb-**** in draw and forget about it..
    The Following User Says Thank You to THE CLASH For This Useful Post:
    Old 03-24-2007, 14:02   #4 (permalink)
    Member: 229658
    No response
    This may indicate damaged EROM area!
    Try repairing the phone via testpoint method.
    If it is an old phone, try converting it to brown first.
    Script error: Unspecified [10.39.41]
    my w550i dosen flash it hangs while waiting for acknowledge... and gives the above message.
    Old 03-24-2007, 16:06   #5 (permalink)
    Member: 9224
    you answer in that message itself.."Try repairing the phone via testpoint method." do it if its CID49 ..
    Old 11-06-2007, 14:40   #6 (permalink)
    Member: 35386
    W550i dead
    HI, I have a SE W550i CID RED 49, it had white screen when you turn it on, I tried to flash it but when flashing main it gave an error and terminated all processes. Now its dead and when I try to attach it with cruiser it gives the following and do not attach, I need help what can I do to solve the situation.
    "System diagnostics passed.
    Version 12.10 ready!
    [ --- Attach to Phone --- ]
    Connecting via UC-10 Universal Cable...
    Powering on the phone...
    Baseband chip ID: 0x8040
    Protocol version: 3.1
    Baudrate = 460800Bd
    Booting via ROM...
    Sony Ericsson phone detected.
    Phone CID: 49
    Phone color: Red
    Flash certificate: A1_DB2010_49_RED
    Trying Red CID49 flash applet...
    Sending applet prologue...
    Sending applet body...
    Time spent entering bootstrap: 1s
    Initializing phone hardware...
    Applet ID: 060206 1814 NPACXC125872_COMPACTPRO...
    Flash manufacturer: ST Microelectronics
    Flash ID: 0x200D
    OTP Security Level: 1 (Retail)
    OTP CID: 49
    Sending applet...
    Terminating threads...
    All threads terminated."
    Old 11-06-2007, 15:00   #7 (permalink)
    amit_varietymob's Avatar
    Member: 399228
    sir u hve to use testpoint method to recover eprom damagae w550i phones. click on any cid use testpoint . Before that give test point to phone. Attach d phone then go to unlock rsa tab, there click on convert to brown first.After that come to flashing part. Now repair damage erom area by pressing on it. Now flash with w550i flash file , generally i flash with r4cb red cid file. first flash arm ,then write raw fs, then customise fs,then shutdown fs. Now check d phone by detaching it through shutdown fs. If still not done then again attach d phone & in rsa tab restore firmware. All done with cruiser.
    The Following User Says Thank You to amit_varietymob For This Useful Post:
    Old 03-12-2008, 10:35   #8 (permalink)
    MUSSARIN's Avatar
    Member: 624653
    Sonork: waseem_jana@yahoo.co.in
    w550i script error pls help me
    w550i erom damage by cruiser ketan.d.chauhan Cruiser Suite 3 04-09-2007 22:00
    ERROR: EROM (Boot) damaged with Cruiser/Recovery option! el_sheik SonyEricsson (USB-Smart) 1 07-22-2006 16:40
    mr zulea z530 damaged with Cruiser/Recovery option! supportallgsm SonyEricsson (USB-Smart) 1 07-13-2006 16:13
    What is solution when detected CID49 EROM (Boot) phone damaged with Cruiser/Recovery Pufi164 SonyEricsson (USB-Smart) 15 07-11-2006 08:35
    EROM (Boot) damaged with cruiser/Recovery option ! GSM SNIPER SonyEricsson (USB-Smart) 9 07-05-2006 18:22
    Page generated in 0.34294 seconds with 12 queries
