w580i phone locked RUNNING v1.0/UNI CARD SERIAL CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35243002790345 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):W580i Brand:Generic MAPP CXC article: R8BE001 prgCXC1123362_GENERIC_LA MAPP CXC version: R8BE001 Language Package: S_ASIA_LEVAN CDA article: CDA102568/1 CDA version: R2A Default article: cxc1123364 Default version: R8BE001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R8BE001_CXC1123362_GENERIC_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED While unlocking w50i with setools following message appears: CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 loader header not accepted FAILED TO SETUP PHONE Elapsed: 3 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35243002790345 CERT:N/A FLASH CID:53 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 1 secs. _______________***************____________________ __ Can will unlock this with hwk. |
you need orig card or test card and signed drivers to unlock cid 53 phone |
SIMLOCKS NOT DETECTED from ur log it shows clearly that phone is not locked. |
*just select in setting sign mode and press unlock/repair button your phone code should be reseted to 0000 as a default:);) |
