Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-29-2010, 16:40 | #1 (permalink) |
Junior Member Join Date: Apr 2007
Member: 492653 Status: Offline Thanks Meter: 8 | W810 IMEI Change Problem the imei is blocked i am tryng to change imei with SETool but on software when imei change option apears and i enter new imei everything is oky! but when i turn on my Handset and check its imei it same old!! i tried different exe verson. and SETool devices. on Exe everything works fine but still on change in imei on handset please help me with this problem |
05-29-2010, 16:49 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Badong's Junkshop
Member: 260632 Status: Offline Thanks Meter: 639 | use rj45 cable .. flash other firmware then check complete, allow change imei ,otp, unlock after flash then post results hope this can help br |
05-29-2010, 18:29 | #3 (permalink) | |
Member: 492653 Status: Offline Thanks Meter: 8 | Quote:
and u mean any firmware of cid49??? hmm well let me try it now then i ll post result | |
05-29-2010, 19:26 | #7 (permalink) | |
v0.91380081/UNI Card serial:00051628 Loaded 51 flash descriptors ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35462301450154 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 Flash ID check:2019 Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS 'TESTPOINT OK' ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:2019 Flash props sent ok Restore from:C:\Documents and Settings\Administrator\Desktop\r4db005_CXC1250316_ GENERIC_HN.ssw.cry writing C:\Documents and Settings\Administrator\Desktop\r4db005_CXC1250316_ GENERIC_HN.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:343 Will flash 343 blocks... SSW loading returns:0 writing C:\Documents and Settings\Administrator\Desktop\r4db005_c_asia_fs.s sw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:161 Will flash 161 blocks... SSW loading returns:0 Searching... Firmware OTP check determined. Setting up GDFS... Clearing total time... Writing simlocks... full sig complete. CSloader version: COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader startup: executed loader filesystem startup: executed loader GDFS startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed:890 secs. | |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
