Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-14-2010, 07:53 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | CID 49 1. select proper model 2. on settings, check "unlock during flash process" 3. add to firmware area proper gdfs in ssw format 4. if desired, add to firmware area proper main,fsimage 5. press flash please note, if EROM damaged on such phones, you must execute reset operation. |
The Following User Says Thank You to roney_nexus For This Useful Post: |
05-22-2010, 21:09 | #3 (permalink) |
No Life Poster Join Date: Mar 2005 Location: wales uk
Member: 125632 Status: Offline Thanks Meter: 233 | can gdfs b flashed with main+fs,in cid49? i thought it was add to firmware area gdfs in ssw format, connect mob with ufs/com (not with usb),press flash.when finished(do not power on the phone), change to usb,+then flash main+fs+customise... only then can u power mob on.... but thats from what i remember,it may not be 100% right... |
06-15-2010, 09:56 | #4 (permalink) |
Freak Poster Join Date: Jul 2008 Location: tangub
Member: 823842 Status: Offline Thanks Meter: 33 | pLS HELP I TRY TO follow this procedure my problem there is error on flashing in mian and fs empty refill tab select model settings tab check sign mode back to empty refill tab tick recovery still in empty refill tab load gdfs and erom tick flash check phone if working..if not goto sony ericssons tab and flash main and fs.... in flashing gdfs and erom here is the logs SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:BE2DA4D42180DD5D15D09852 P96 AUTH PASSED OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 10 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se tool file\gdfs_in_ssw_format\db2020\K610_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "70762201" SIGNING... Elapsed: 217 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se tool file\eroms\db2020\DB2020EROM_BROWN49_BROWN_CID49_D B2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 80 Will flash 4 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "50831286" SIGNING... Elapsed: 44 secs. flashing logs pls. error CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901338317 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se tool file\SE Flash Files\K610\R1EJ001_1250374_GENERIC_TH.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 10 secs. |
06-15-2010, 12:19 | #5 (permalink) | |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
* mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 k610 after successful RECOVERY * switch to empty board tab * select k610 * add k610_GDFS_SSW.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 k610 * flash with red 52 firmware check on settings signed mode "customize phone after flash" * DONE. | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
