Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
04-25-2009, 14:22 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: karachi
Member: 643460 Status: Offline Thanks Meter: 93 | w850 how to change imei w850 helpppp so i upgrade its uroum and its cid going to cid53 also try many time imei cannot b change/..... even i try like cid 52 w200 change imei pice going to dead and see gdfs crupt and after flashing again ok..... 4/23/2009 3:29:50 PM Speed:921600 4/23/2009 3:29:50 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:352401012***** CERT:N/A 4/23/2009 3:29:50 PM FLASH CID:53 COLOR:RED 4/23/2009 3:29:51 PM PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 4/23/2009 3:29:51 PM LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 4/23/2009 3:29:51 PM Flash ID check:897E 4/23/2009 3:29:51 PM Flash props sent ok 4/23/2009 3:29:53 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 4/23/2009 3:29:53 PM loader startup: executed 4/23/2009 3:30:06 PM loader GDFS startup: executed 4/23/2009 3:30:07 PM loader filesystem startup: executed 4/23/2009 3:30:07 PM loader unlock: executed 4/23/2009 3:30:12 PM 4/23/2009 3:30:12 PM DISCONNECT PHONE NOW 4/23/2009 3:30:12 PM INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 4/23/2009 3:30:12 PM INSTALL PHONE MODEM DRIVERS IF NEEDED 4/23/2009 3:30:12 PM 4/23/2009 3:30:12 PM SEARCHING FOR PHONE, "STOP" TO ABORT 4/23/2009 3:37:22 PM PHONE FOUND AT COM50 4/23/2009 3:37:29 PM SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. 4/23/2009 3:37:29 PM Elapsed: 472 secs. 4/23/2009 3:42:36 PM SIGNED MODE (USING SERVER) 4/23/2009 3:42:36 PM ALTERNATIVE SECURITY BYPASS ENABLED. 4/23/2009 3:42:41 PM ChipID:9900,EMP protocol:0301 4/23/2009 3:42:41 PM BOOTROM MODE DETECTED 4/23/2009 3:42:41 PM Speed:921600 4/23/2009 3:42:41 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:3524010****9 CERT:N/A 4/23/2009 3:42:41 PM FLASH CID:53 COLOR:RED 4/23/2009 3:42:42 PM PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 4/23/2009 3:42:42 PM LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 4/23/2009 3:42:42 PM Flash ID check:897E 4/23/2009 3:42:42 PM Flash props sent ok 4/23/2009 3:42:44 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 4/23/2009 3:42:44 PM loader startup: executed 4/23/2009 3:42:56 PM loader GDFS startup: executed 4/23/2009 3:42:58 PM loader filesystem startup: executed 4/23/2009 3:42:58 PM loader unlock: executed 4/23/2009 3:43:02 PM 4/23/2009 3:43:02 PM DISCONNECT PHONE NOW 4/23/2009 3:43:02 PM INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 4/23/2009 3:43:02 PM INSTALL PHONE MODEM DRIVERS IF NEEDED 4/23/2009 3:43:02 PM 4/23/2009 3:43:02 PM SEARCHING FOR PHONE, "STOP" TO ABORT 4/23/2009 3:43:39 PM PHONE FOUND AT COM50 4/23/2009 3:43:45 PM PHONE READY TO PROCEED 4/23/2009 3:43:51 PM EXECUTOR STARTED 4/23/2009 3:43:51 PM 4/23/2009 3:43:51 PM REMOVE CABLE FROM PHONE 4/23/2009 3:43:51 PM REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK 4/23/2009 3:43:51 PM THEN PRESS "READY" 4/23/2009 3:44:04 PM 4/23/2009 3:44:17 PM ChipID:9900,EMP protocol:0301 4/23/2009 3:44:17 PM BOOTROM MODE DETECTED 4/23/2009 3:44:17 PM Speed:921600 4/23/2009 3:44:18 PM Trying to launch embedded bootloader... 4/23/2009 3:44:48 PM embedded flashloader not responds ! |
04-25-2009, 15:00 | #2 (permalink) | |
Freak Poster Join Date: Aug 2008 Location: Pleven, Bulgaria Age: 42
Member: 830767 Status: Offline Thanks Meter: 9 | Quote:
w850 how to repair imei mismatch | ali_imran | SETool2 | 7 | 01-20-2010 19:01 |
How to change IMEI to Samusung E370 ? | peter24533 | NSPRO | 1 | 10-18-2007 17:05 |
How to change imei to a nokia 3220 RH-49 V05.01 | tito millo | Universalbox | 0 | 08-01-2007 00:06 |
how to change imei to t290i with cruiser ? | cellularman | Cruiser Suite | 3 | 08-08-2006 09:02 |
3200 want to check how to change imei and phone dead :) | PSG | Griffin | 4 | 01-08-2006 22:08 |
