Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-28-2010, 05:27 | #1 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1013158 Status: Offline Thanks Meter: 0 | W850i GDFS showing K700 even after Reset opteration CARD SERIAL xxxxxxxxxx SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110100000000 ChipID:9900,EMP protocol:0301 Speed:115200 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35282601066679 CERT:N/A FLASH CID:49 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1EJ001 prgCXC1250204_CHINA_CY MAPP CXC version: R1EJ001 Language Package: EUROPE_4 CDA article: CDA102568/13 CDA version: R2A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:111100000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:6E95BB1521803A6215704710 P96 AUTH PASSED OTP: LOCKED:1 CID:49 PAF:1 IMEI:35282601066679 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 39 secs. SIGNED MODE (USING SERVER) CFG:111000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35282601066679 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "G:\v1.01\gdfs_in_ssw_format\db2020\w850_gdfs_ ssw. ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... writing "G:\v1.01\eroms\db2020\DB2020EROM_CNV_RED53_BR OWN_ CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "42674628" SIGNING... Elapsed: 237 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35282601066679 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "G:\file setool\w850\cid 53\R1KG001_1250204_CHINA_CY.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "G:\file setool\w850\cid 53\R1KG001_FS_APAC_CY_RED_CID53.software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 5140 Will flash 257 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 873 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35282601066679 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):W850i Brand:Generic MAPP CXC article: R1ED001 prgCXC1250200_GENERIC_CY MAPP CXC version: R1ED001 Language Package: EUROPE_4 CDA article: CDA102568/13 CDA version: R2A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SEARCH:G:\file setool\w850\cid 53\R1KG001_1250204_CHINA_CY.ssw SEARCH:G:\file setool\w850\cid 53\R1KG001_FS_APAC_CY_RED_CID53.software RESTORATION FILE NOT PRESENT "R1ED001_CXC1250200_GENERIC_CY" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35282601066679 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1KG001 prgCXC1250204_CHINA_CY MAPP CXC version: R1KG001 Language Package: EUROPE_4 CDA article: CDA102568/13 CDA version: R2A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SEARCH:G:\file setool\w850\cid 53\R1KG001_1250204_CHINA_CY.ssw "R1KG001_CXC1250204_CHINA_CY" CREATED Elapsed: 14 secs. help me |
05-28-2010, 06:58 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
05-28-2010, 07:07 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: sangam music Punjab India Age: 38
Member: 296651 Status: Offline Sonork: 100.1581376 Thanks Meter: 386 | Quote:
The Following User Says Thank You to sonumobilewala For This Useful Post: |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
5110 v 6.0 after unlocking problem with net | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 16:11 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
