Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
The Following User Says Thank You to krejziajwan For This Useful Post: |
The Following User Says Thank You to braing For This Useful Post: |
10-25-2008, 11:16 | #3 (permalink) |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | k800i firmware hello this is the information i got from sedbox (ufs3+hwk software) SHUT DOWN FL ... MCU_ID : 99000301FFFFFFFF S_BAUD : 921600 P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 51 RED IMEI : 354716-01-660212-0 CD_PAF : 1 0 1 OTPCID : 51 RED CID_UP : 5151 CXC_NR : cxc1250490 R1ED001 CDA_NR : CDA102239/43 R15A CIDUP Canceled P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 FLSH_ID: 897E [Intel SIBLEY] P_LOAD : 070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 CXC_NR : cxc1250490 R1ED001 CDA_NR : CDA102239/43 R15A Country: EUROPE_2 JAVA : Profile/MIDP-2.0 Configuration/CLDC-1.1 Modem : Sony Ericsson IrDA Modem 039,Sony Ericsson Device ITP_SW : CXC 125 0310 R2N KRH_Inf: CB5A095EVJ ERR_Log: 2E0W SHUT DOWN CS ... which flash file can i use to flash this k800i its only bringing white screen and some time bringing option for normal mode or flight mode |
The Following User Says Thank You to kachman For This Useful Post: |
10-28-2008, 21:33 | #5 (permalink) |
Junior Member Join Date: Sep 2008
Member: 853162 Status: Offline Thanks Meter: 0 | hola a todo tengo este problema quien me puede hayudar k800i v0.914037/UNI CARD SERIAL: 00090975 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 26 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701428710 CERT:N/A FLASH CID:52 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit PROCEDURE WAS STOPPED BY USER Elapsed: 39 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701428710 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok CSCA UNLOCK ONLY SUPPORTED ON DCU60 ! Elapsed: 24 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701428710 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok CSCA UNLOCK ONLY SUPPORTED ON DCU60 ! Elapsed: 14 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35342701428710 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok writing M:\setool\setool\flash files\w800\R1CB001_1250210_GENERIC_WI.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9100 Will flash 455 blocks... SSW loading returns:0 writing M:\setool\setool\flash files\w800\R1CB001_FS_EUROPE_1_WI_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4260 Will flash 213 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 781 secs. |
07-03-2011, 15:05 | #9 (permalink) |
Registered User Join Date: Sep 2008 Location: HardWare+Software & Unlocking
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | k800 flash setool v0.915057/UNI CARD SERIAL: 00083285 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701997132 CERT:RED FLASH CID:49 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: R1CB001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1CB001 Language Package: M_EAST_N_AFR CDA article: CDA102511/2 CDA version: R2A Default article: cxc1250490 Default version: R1CB001 PROVIDER: MULTIPLE Network LOCKED SEARCH:C:\Documents and Settings\My Phone\My Documents\Downloads\Compressed\K800 cid 49(http://www.freeflashfile.com)\r1cb00...RIC_WI.ssw.cry "R1CB001_CXC1250210_GENERIC_WI" CREATED SECURITY UNITS BACKUP CREATED. Elapsed: 23 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701997132 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 bypassing security... server step1 error:bad username/password. loader unlock failed, that is fatal Elapsed: 14 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701997132 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 bypassing security... server step1 error:bad username/password. loader unlock failed, that is fatal Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:110000000000 bad username/password. CARD COUNTERS: FLASH 83, UNLOCK 15 Elapsed: 2 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701997132 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM32 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Starting embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 FLASH ID:2019 FOUND VERSION "R1CB001_CXC1250210_GENERIC_WI" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 262 secs. |
07-03-2011, 15:08 | #11 (permalink) |
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | k800 all flash link K800_R1GB001_FS_AMERICA_2_RED49: http://netload.in/datei5fa672196f16b..._RED49.rar.htm K800_R1GB001_FS_CENT_EUROPE_RED49: http://netload.in/dateif5c29d6b51ddd..._RED49.rar.htm K800_R1GB001_FS_ORANGE_GEN_RED49: http://netload.in/dateie2de839102685..._RED49.rar.htm K800_R1GB001_MAIN_GENERIC_RED49: http://netload.in/dateibeba5aa7ea797..._RED49.rar.htm K800_R1GB001_MAIN_ORANGE_RED49: http://netload.in/datei210b6dc661181..._RED49.rar.htm K800_R1JC002_FS_CENT_EUROPE_RED51: http://netload.in/datei4038a75e2926a..._RED51.rar.htm K800_R1JC002_FS_CENT_EUROPE_RED52: http://netload.in/dateid0a27c68c4160..._RED52.rar.htm K800_R1JC002_FS_ORANGE_GEN_RED52: http://netload.in/dateicc54b82950e8e..._RED52.rar.htm K800_R1JC002_MAIN_GENERIC_WI_RED51: http://netload.in/datei1184435155d26..._RED51.rar.htm K800_R1JC002_MAIN_GENERIC_WI_RED52: http://netload.in/datei016840b5aca98..._RED52.rar.htm K800_R1JC002_MAIN_ORANGE_RED52: http://netload.in/datei7c00a8dd1b90e..._RED52.rar.htm K800_R1JG001_FS_CENT_EUROPE_RED52: http://netload.in/dateid98ec337faf31..._RED52.rar.htm K800_R1JG001_FS_ORANGE_GEN_RED52: http://netload.in/dateif1ef0b8708338..._RED52.rar.htm K800_R1JG001_MAIN_GENERIC_WI_RED52: http://netload.in/datei585a6bb523864..._RED52.rar.htm K800_R1JG001_MAIN_ORANGE_WI_RED52: http://netload.in/datei1f48bbf17e513..._RED52.rar.htm K800_R1KG001_FS_APAC_RED52: http://netload.in/datei3e3b512f75a2a..._RED52.rar.htm K800_R1KG001_FS_BALTIC_RED52: http://netload.in/datei3c8324035cd3b..._RED52.rar.htm K800_R1KG001_FS_CENT_EUROPE_RED52: http://netload.in/datei52afed44e276a..._RED52.rar.htm K800_R1KG001_FS_C_ASIA_RED52: http://netload.in/dateid3bcb58c2cb5d..._RED52.rar.htm K800_R1KG001_FS_EUROPE_1_RED52: http://netload.in/dateid556e488f9f37..._RED52.rar.htm K800_R1KG001_FS_EUROPE_2_RED52.rar: http://netload.in/datei4e15dce53199e..._RED52.rar.htm K800_R1KG001_FS_EUROPE_3_RED52: http://netload.in/datei7101dcf24c86a..._RED52.rar.htm K800_R1KG001_FS_EUROPE_4_RED52: http://netload.in/dateicdb8fbd3941d5..._RED52.rar.htm K800_R1KG001_FS_EUROPE_5_RED52: http://netload.in/datei589a18f77dede..._RED52.rar.htm K800_R1KG001_FS_HUTCH_1_RED52: http://netload.in/dateifd46efc567388..._RED52.rar.htm K800_R1KG001_FS_MEDITERR_RED52: http://netload.in/datei7ed6eca4b7ed4..._RED52.rar.htm K800_R1KG001_FS_M_EAST_N_AFR_RED52: http://netload.in/dateid66c150adb10d..._RED52.rar.htm K800_R1KG001_FS_ORANGE_GEN_RED52: http://netload.in/datei7ecdee268bfa1..._RED52.rar.htm K800_R1KG001_FS_RUSSIA_RED52: http://netload.in/datei0417c1892470a..._RED52.rar.htm K800_R1KG001_FS_S_E_EUROPE_RED52: http://netload.in/dateid5b4864ec85ac..._RED52.rar.htm K800_R1KG001_FS_TAIWAN_RED52: http://netload.in/datei00f3c2305ef4a..._RED52.rar.htm K800_R1KG001_FS_T_MOB_INT_A_RED52: http://netload.in/datei1c798e81e8410..._RED52.rar.htm K800_R1KG001_FS_T_MOB_INT_B_RED52: http://netload.in/datei56dc1e00f7d4d..._RED52.rar.htm K800_R1KG001_FS_VFE_LIVE_1_RED52: http://netload.in/datei29b432e975547..._RED52.rar.htm K800_R1KG001_FS_VFE_LIVE_2_RED52: http://netload.in/dateiae226cbbf0869..._RED52.rar.htm K800_R1KG001_MAIN_CHINA_WI_RED52: http://netload.in/dateifd93867b22e9e..._RED52.rar.htm K800_R1KG001_MAIN_GENERIC_WI_RED52: http://netload.in/datei2559f3ee39d9e...RED52.rar.htm\ K800_R1KG001_MAIN_HUTCHISON_WI_RED52: http://netload.in/datei29875ae4a96ef..._RED52.rar.htm K800_R1KG001_MAIN_ORANGE_WI_RED52: http://netload.in/datei7e2807d51806c..._RED52.rar.htm K800_R1KG001_MAIN_TAIWAN_WI_RED52: http://netload.in/datei18cd0b060d10c..._RED52.rar.htm K800_R1KG001_MAIN_VODAFONE_WI_RED52: http://netload.in/dateifd44d4a0beaac..._RED52.rar.htm K800_R1KG001_MAIN_YOIGO_WI_RED52: http://netload.in/dateie594c74853297..._RED52.rar.htm K800_R8BA024_FS_CENT_EUROPE_RED52: http://netload.in/dateif700ffd3e6245..._RED52.rar.htm K800_R8BA024_FS_CENT_EUROPE_RED52: http://netload.in/datei91a78b3916853..._RED52.rar.htm K800_R8BA024_MAIN_GENERIC_WI_RED52: http://netload.in/datei7bf0491c03f9a..._RED52.rar.htm K800_R8BA024_MAIN_GENERIC_WI_RED52: http://netload.in/datei232d5e60a3626..._RED52.rar.htm K800_R8BC004_FS_BALTIC_RED52: http://netload.in/datei1d46feda6f43e..._RED52.rar.htm K800_R8BC004_FS_CENT_EUROPE_RED52: http://netload.in/dateif91e39352e9e2..._RED52.rar.htm K800_R8BC004_FS_C_ASIA_RED52: http://netload.in/datei6540b50ed3b26..._RED52.rar.htm K800_R8BC004_FS_EUROPE_2_RED52: http://netload.in/datei8e2cae6fdf436..._RED52.rar.htm K800_R8BC004_FS_MEDITERR_RED52: http://netload.in/dateic69665201b92e..._RED52.rar.htm K800_R8BC004_FS_ORANGE_GEN_RED52: http://netload.in/datei039b14216f5cf..._RED52.rar.htm K800_R8BC004_FS_RUSSIA_RED52: http://netload.in/dateie9aac5b5a1ab1..._RED52.rar.htm K800_R8BC004_FS_S_E_EUROPE_RED52: http://netload.in/datei91f16afcc43aa..._RED52.rar.htm K800_R8BC004_MAIN_GENERIC_WI_RED52: http://netload.in/datei2e44900d9b0bc..._RED52.rar.htm K800_R8BC004_MAIN_ORANGE_WI_RED52: http://netload.in/dateic304ad330485e..._RED52.rar.htm |
10-15-2011, 06:54 | #12 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | Quote:
i need kp135 flash file [USER REQUEST] | sameenshah123 | PolarBox 3 | 5 | 03-29-2010 16:08 |
i need 1650 flash file without games | med26 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-29-2010 11:11 |
k800 flash file is cannot download | phoneteam | Multi-Box | 2 | 01-03-2008 16:28 |
Hack LG k800 Flash File | Formingus | LG | 1 | 07-07-2007 08:32 |
