Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
12-30-2006, 07:20 | #1 (permalink) |
Junior Member Join Date: Dec 2006 Location: Mexico Age: 40
Member: 421325 Status: Offline Thanks Meter: 0 | CID 49 Flashing debrand with Phone XS V2 for free A) flash CID49 DB2010/DB2020 phones with PhoneXS 2 (by gbrooks3 & hendrix) If you only want to upload / delete some files: B) Uploading & deleting files with PhoneXS 2 First of all: Important: It may take up to 5 hours!! to finalize your phone. / Once you have started the procedure there's no way back So don't flash your phone, if you need it in the next few hours. VERY IMPORTANT THINGS: + You can download PhoneXS here: http://www.uploads.sc/download.php?file=70...a61dca41b7e6b7d (2.10 Alpha3) + make sure that main firmware flash file & filesystem flash file & custpacks are available for your phone BEFORE you start flashing + After flashing a filesystem flash file, DON'T turn your phone on, until you have customized it + Always charge your battery to 100% before flashing + Remove SIM card & memorystick before flashing + If your phone is not recognized, remove battery & insert it again +Use this tool with a DCU-60 cable (standard usb cable that came with your phone) or a service cable of your choice + Always use the latest USB drivers Warning: Don't flash GSlide Firmwares to W810 - not possible at the moment! a) Flashing with Phone XS 2 That really easy, we'll just need a) Firmware main file b) Filesystem file Sources for these files: Firmware main + filesystem: http://www.topsony.com/foro/cmps_index.php?page=Firmwares In this example we'll flash a K800 with firmware R1ED001 Generic and filesystem EUROPE_2. So we'll head to topsony.com and download these 2 files: K800_R1ED001_MAIN_GENERIC_WI_RED49.rar K800_R1ED001_FS_EUROPE_2_RED49.rar As these are .rar files, we have to extract them. That gives us: K800_R1ED001_MAIN_GENERIC_WI.mbn K800_R1ED001_FS_EUROPE_2.fbn Now it's time to download & start Phone XS. The first thing we have to do, is to select the cable we are using. We'll use a USB DCU60 (standard usb cable) in this example, which means we have to select "USB" and press "Connect". Now PhoneXS profiles our phone and outputs some information: As we are going to flash our phone with MAIN and FS (filesystem) firmware, We activate "Flash Main", "Flash File System" and "Customize File System" and use K800_R1ED001_MAIN_GENERIC_WI.mbn as "Main Firmware" and K800_R1ED001_FS_EUROPE_2.fbn as "File System". Because we are flashing a filesystem we also have to customize. To do that we select a compatible CDA. As we are flashing a EUROPE_2 filesystem, we use a EUROPE_2 custpack. Finally click "Flash" and PhoneXS will do its magic. Note: After clicking "Flash" it can take up to 5 hours to finish the procedure. If the programm hangs after a while, your phone is most likely low on power >> recharge it That's all |
12-30-2006, 22:57 | #6 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 47
Member: 104560 Status: Offline Thanks Meter: 0 | I can't find customization file for K800_R1ED001_FS_BALTIC_RED49... Could anyone please suggest where could I find one? Regards Last edited by Lyncas; 12-30-2006 at 23:39. |
12-31-2006, 06:41 | #7 (permalink) | |
Member: 421325 Status: Offline Thanks Meter: 0 | Quote:
http://www.topsony.com/foro/cmps_ind...?page=CDA_K800 regards | |
12-31-2006, 15:42 | #8 (permalink) |
Member: 104560 Status: Offline Thanks Meter: 0 | No - it's not there, neither in se-nse... I've checked it before asking in this forum. Any ideas where to get it? It should be something like K800i_CDA102511_1_BALTIC... |
01-01-2007, 10:08 | #9 (permalink) |
Junior Member Join Date: Mar 2006
Member: 240742 Status: Offline Thanks Meter: 0 | Well since it's free and most people want that, a lot of them just happliy waits for their phone It's not a service center tool u know... And if you have a DB2010 CID49, u can always patch it and have instant customization |
w580i cid 49 flash file need but spport side only 52/53 cid plz help | R@jusat | SETool2 | 10 | 09-20-2013 09:49 |
W850i OTP CID 49, flash CID 52, can i flash it or it will be locked? | Mantelis | Cruiser Suite | 13 | 09-20-2007 22:52 |
Flashing with Phone XS 2 | gsm-iran | Sony Ericsson | 3 | 04-09-2007 15:34 |
K750i CiD 49 Red Vodaphone - Dead Phones Need assistance :D | Tanjitsu | Cruiser Suite | 8 | 11-29-2006 16:38 |
i need W810i CID 49 flash file for fix CRC error. phone dead - uncompleted unlock | PSG | SonyEricsson (USB-Smart) | 5 | 08-22-2006 21:30 |
