Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola CDMA
Motorola CDMA here all threads Related to Motorola CDMA Hardware Servicing and Repairing.
Old 05-09-2009, 15:07   #1 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
Thumbs down Motorola cdma code
Motorola 7760, 7860, 2260, 8160, etc Nam Programming:
Nam Set: Fcn,0000000000000, Rcl
Nam Set: 74663#, Fcn, Fcn
Test Mode: Fcn, 00**83786633, Sto
Motorola v60c, v120c etc Nam Programming:
Nam Set: 74663#, Menu, Menu, Spc
Nam Set: Menu, 073887, * (type quickly)
Test Mode: Menu, 073887*, Spc
Debug Mode: ##33284
Force the
[COLOR=blue! important][COLOR=blue! important]phone[/COLOR][/COLOR] into DIGITAL ONLY mode:
1) ##33284 (Debug)
2) RIGHT Softkey (Next) Twice
3) Down arrow 10 times to "PrefMod"
4) RIGHT Softkey (Change) until you see "DigOnly"
5) LEFT softkey (Exit)
6) MENU then LEFT Softkey return to idle screen
7) ##33284 (The last 4 will not display if you have done it correctly)
Motorola t182, c210, etc Nam Programming:
Nam Set: ##1111 end
Nam Set: ##298645665 end
Short Nam: ##073887 sto
Motorola v710, v730, v740, ms150, etc Nam Programming:
Nam Set: 8378*# + press 3 times NATE (spc - 071082)
Service Menu: #758353266#646#
Motorola StarTac 2004 Nam Programming:
Nam Set: 5759789*#, rec key (3)times (spc - 915037)
Motorola ms200, ms230, etc Nam Programming:
Nam Set: 5759789*# (spc - 915037)
Motorola v6060 Nam Programming:
Nam Set:147*369#456*0#
MOTOROLA TEST MODE:
v60, c120, c331, etc:
1) Turn on the phone. Press MENU 0 7 3 8 8 7 *
2) The phone will require you to "Enter a
[COLOR=blue! important][COLOR=blue! important]Security[/COLOR][/COLOR] Code", press 000000, OK
3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable"
choose SELECT. Your phone is now in test mode.
4) Signal strength is the 3_rd number down on the left hand side of the screen.
5) To toggle between regular mode and test mode: Press MODE then
quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU.
6) To turn off the test mode the phone must be in regular mode, then follow
the above sequence and scroll down to where it says "DISABLE" instead of
"ENABLE" and choose select.
Thanks" Button to say Thanks
The Following 4 Users Say Thank You to Gsmbizz For This Useful Post:
Motorola CDMA Codes samirov-gsm Motorola ODM 3 03-21-2009 09:41
how to remove user code in V720 motorola cdma Chandreshswami Motorola CDMA 2 12-06-2008 11:37
..motorola cdma ESN changer .. PlayBoy Motorola Old Legacy (EMMI) 0 10-04-2002 13:07
ESN changer for Motorola cdma solomons Motorola Old Legacy (EMMI) 5 09-25-2002 13:25
ESN changer for Motorola cdma solomons Main Sales Section 0 09-19-2002 11:13
Page generated in 0.12473 seconds with 9 queries
