12-13-2014, 16:00 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2089180 Status: Offline Thanks Meter: 18 | How to know wich flash file to use for LG GT505 Warning: For proper work, battery must be fully charged Reconnect battery, press and hold volume up button, connect cable to the phone If phone is not connecting, solder testpoint Port opened, waiting for phone ping... CPU: DB3200 P3A/R3A Ericcson Mobile Platform: v4.1 Chip Class: 0x00020000 Fuse Locks: RETAIL SECURITY Security Domain (Color): RED (retail) OTP Lock: Locked OTP CID: 54 OTP PAF: 0 OTP IMEI: xxxxxxxxxxxxxxxxx Flash CID: 54 Flash PAF: 0 IMEI: xxxxxxxxxxxxxxxxxxx Effective CID: 54 Effective PAF: 0 Sending ACC Preloader Sending APP Preloader Sending ACC Loader Sending APP Loader Connected V10A OR B OR C OR D OR E OR F OR G OR H OR I |
12-13-2014, 18:00 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | As with many other people, I found the orange firmware restricts your phone and stops many of the features working. Looking for a solution, I found on another forum a method of replacing the orange firmware with the original firmware. I tried it and it worked perfectly and now all the features are available. Step by step! 1. Download the GT505 Mega Pack (In this all) from the link on my post was up to mediafire. 2. Unzip it as normal 3. A folder will be created with the name 'LG GT505 Mega Pack' includes 5 Foder 4. Open the folder LG GT505 newsletter to Foder 'Logiciel 1'. and lick on LGDP2_31_INCLUDE_LGDP1_Setup.exe enter the serial number that came in to finish the installation process. 5. Next, you open to 'Logiciel 2' (only one file here), and copy it into the "C: \ Download". (Directory has been set up above) 6. In the folder "C \ Download 'find' LGDP2_CS '. Double click on it and click on 'OK' To register registry 7. Go back to the 'LG GT505 ...' look to the folder 'USB Drivers. Double click on the 'installme' to setup the driver for it = >> done. 8. Turn off the phone, press and hold the volume button + "and connected to the USB cable. hold for 3 seconds. 9. Your computer will ask to install the driver. Select manually and take the path to the folder USB Drivers 10. Next to the 'C \ Download "folder to find' LGDP2_V35_UMTS 'and open it up 11. In the Division Selection 'choose' UMTS 'and click OK! Until patio table to Port selection. 12. In Port selection, tick the 'COM1' and deselect (if any), all other COM. next to the bottom in the 'DLL SELECTION', click the icon to the left and find the DLL file in LG GT505 Mega Pack \ DLL \ GT500_090601_MP.dll '= >> click ok to select> 13. Click 'Run Configuration and Download window opens. Chon to Use USB Address select 'COM 1' and disconnect the phone to the computer. Press and hold the Volume + 'and reconnect the USB cable. On the screen, click on the 'SET' and once then appear under 'UsbAddr' 14. At the same expression on LGE Image Tool you lick and lick on the 'Add', the heart of the file to the root directory LG GT505 Mega Pack, select Firmware_V10B file and select all of the files shown 15. Repeat for the 'LGE GDFS' and then click 'OK' to delete the icon. 16. Click on the 'START' at the top of the screen, disconnect the phone and hold the Volume + button and reconnect the USB cable for Flashing 17. When finished immediately flashed the 'COM1' porch on the notice board 'IDLE. Meanwhile, you can press' STOP' and disconnect your phone - that's it. DIDONGCLUB.NET LG GT505 Mega Pack |
