Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG CDMA
Old 04-24-2009, 08:22   #1 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 60
Lg rd 3500 3510 3600 3000 3100 flashing problem
dear all respected forum members kindly help me for lg flashing because some times all these models flash well but some time menu dissapear and network loss and some time it is stopped in code erase.kindly help me first i was flash it with lg tool then it got the problem like first one when i flsh it with old lg downloder it give the problem like second one.l
The Following 6 Users Say Thank You to mayank bajaj For This Useful Post:
Old 04-24-2009, 11:33   #2 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 60
pls help me sir.thanks for help
Old 04-24-2009, 16:31   #3 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,376
post here prcedure which is follow by u so i can help u where u is wrong in procedure
Old 04-24-2009, 16:41   #4 (permalink)
Member: 185776
Thanks Meter: 73
Lg Rd 3000 while unlocking this erroe msg coming
The Following User Says Thank You to cellbhai For This Useful Post:
Old 04-24-2009, 16:50   #5 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,376
why u use lg tool 4 unlock rd 3000 use lg downloader 1.3.9.10 and select all files
first selct dll file then bin file,scr file,prl and eri file than press upgrade
The Following User Says Thank You to rehmani For This Useful Post:
Old 04-25-2009, 06:53   #6 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 60
sir i have select bin file of lg 3500 and dll of lg rd 2230 it connected and write ram file but it hase been stoped in code erase and when i flash with lg downloader with select all file it has been flash compleet but no menu pictures display no network when i go for scr it it wont scr help me what to do.
The Following User Says Thank You to mayank bajaj For This Useful Post:
Old 04-25-2009, 08:28   #7 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,376
Old 04-25-2009, 08:44   #8 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,376
why u select lg 2230 dll can u explain .to avoid any problem you select all files of 3500
Old 04-25-2009, 10:08   #9 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 60
but in emergency flash it is asking only 2 files.
Old 04-26-2009, 07:58   #10 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 60
sir kindly post actual procedur of flashing.
Old 04-26-2009, 08:02   #11 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,050
first put battery in full charge.
2nd push cable & battery in set.
3rd press power+ 5 bottom
4th use lgtools & untick dibugging.
Press emargency flash
that's all.
The Following 2 Users Say Thank You to debmobile For This Useful Post:
Old 04-26-2009, 08:49   #12 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 60
i do this procedure but after this menu dissapear and network loss.
Old 04-26-2009, 10:30   #13 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,376
this procedure which is u following only for emergency mode. this metod is mostly used when set is blinking position.and after emergency flashing u must need to write prl and scr filr for menu settings and network
Old 04-26-2009, 10:43   #14 (permalink)
Member: 759645
Sonork: MANNU
Thanks Meter: 60
but it wont take scr file even it is not connected when set came at me it was blinking,.
Old 04-26-2009, 10:44   #15 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 679
no working plz test and post
lg RD-3500/3600 blinking solution ashish_1212 LG CDMA 114 11-10-2014 14:24
rd.3500.3510.3600.unlock.flash.file honolulu Various CDMA/TDMA Cell Phones 4 07-29-2009 20:13
lg 3500 3510 3600 sonunarang Various CDMA/TDMA Cell Phones 4 04-13-2009 15:33
Remove lg 3500/3510/3600 user lock with nokia cable skagrll Various CDMA/TDMA Cell Phones 5 01-25-2009 19:52
lg rd 3500/3510 unlocking bin ranagaurav Various CDMA/TDMA Cell Phones 6 01-20-2009 09:17
Page generated in 0.69343 seconds with 9 queries
