Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn > Karbonn Hardware Repair
Old 10-06-2013, 14:57   #1 (permalink)
Member: 1102263
k9 keypad not working
karbonn k9 2,5,8,0,keys not working plz help me
The Following User Says Thank You to VASAKISHORE For This Useful Post:
Old 10-06-2013, 15:12   #2 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
rehot or change cpu....
The Following User Says Thank You to nafe2me For This Useful Post:
Old 05-12-2017, 04:56   #3 (permalink)
Member: 2716245
Question k9 mobile key pad not working,4 buttons only working those are (8,9& on /off button)
Old 05-14-2017, 17:59   #4 (permalink)
Member: 2437841
Thanks Meter: 2
just change charging base
The Following User Says Thank You to Mr.Bajwa For This Useful Post:
Old 07-06-2017, 19:22   #5 (permalink)
Member: 2488294
At first try to change the charging base if not solved then change the CPU and just flash ur problm 100 solved
The Following User Says Thank You to subhankarpaul For This Useful Post:
Old 10-26-2017, 16:16   #6 (permalink)
Member: 2344595
Thanks Meter: 4
Chenge charging soket
Old 10-27-2017, 11:54   #7 (permalink)
Member: 2772362
Karbon k9 white display problem
Old 10-30-2017, 12:14   #8 (permalink)
Member: 2771239
Thanks Meter: 3
My friend has faced the same problem with Karbon k9 mobile. He took it to the repair shop and they changed the CPU
The Following 2 Users Say Thank You to sanaafreen For This Useful Post:
Old 10-29-2018, 18:09   #9 (permalink)
Member: 2874309
change the charging connector 100% solve this problem
Old 10-30-2018, 16:08   #10 (permalink)
Member: 744022
Thanks Meter: 33
just rehot cpu or change cpu
Old 11-04-2018, 15:04   #11 (permalink)
mohdfaizan987's Avatar
Member: 2376362
Sonork: 1664031:mohd
Thanks Meter: 49
First change the charging jack & if possible
Share this pic of PCB Both Sides
Old 11-07-2018, 10:53   #12 (permalink)
Member: 2789232
any other solution ?
Old 08-16-2019, 16:50   #13 (permalink)
Member: 2869632
Sonork: rehal75
I dnt think its problem in charging cpu but i say there path line demage let chk with digital multimeter and put jumper
Page generated in 0.18284 seconds with 8 queries
