k9 keypad not working karbonn k9 2,5,8,0,keys not working plz help me |
rehot or change cpu.... |
k9 mobile key pad not working,4 buttons only working those are (8,9& on /off button) k9 mobile key pad not working,4 buttons only working those are (8,9& on /off button):eek: |
just change charging base |
At first try to change the charging base if not solved then change the CPU and just flash ur problm 100 solved |
Chenge charging soket |
Karbon k9 white display problem |
My friend has faced the same problem with Karbon k9 mobile. He took it to the repair shop and they changed the CPU |
change the charging connector 100% solve this problem |
just rehot cpu or change cpu |
First change the charging jack & if possible Share this pic of PCB Both Sides |
any other solution ? |
I dnt think its problem in charging cpu but i say there path line demage let chk with digital multimeter and put jumper |
