03-12-2013, 11:43 | #6 (permalink) |
Banned Join Date: Feb 2013
Member: 1891179 Status: Offline Sonork: 100.1627755 Thanks Meter: 50 | no need to change cpu or reball cpu just follow the below step for all type of chines follow the below steps for all type of chinese mobiles white lcd solution 100000000000000000 % working and 100000000 time tested ........... first of all resold it in good way if not work then remove camera and check if not work yet then remove lcd and check all track may one of the track is miss if any miss then make jumper and make it ok and check by pasting lcd if not working after that then you have to change lcd ......... regards........... |
03-12-2013, 20:22 | #7 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | Quote:
Its impossible in mstar 8533c/85xx cpu... its some time work...if set is water damage... but mstar 8533c 90% cpu problem.. | |
03-29-2013, 21:34 | #10 (permalink) |
Freak Poster Join Date: May 2004 Location: algeria
Member: 64587 Status: Offline Thanks Meter: 39 | i offten just resold the display ,but if it goes white after few seconds you must change the display,if its white from the start resold it or flash the set ,sometimes change the big capacitors on the display strip |
09-26-2013, 08:10 | #13 (permalink) |
Junior Member Join Date: Nov 2010 Location: suryapet,
Member: 1441738 Status: Offline Sonork: shankar.anu200@!gmail.com Thanks Meter: 3 | Karbonn K9New ringer not working please hlp me bro. karbon k9new ringer not working please any solution bro... |
The Following User Says Thank You to shankar2000 For This Useful Post: |
09-26-2013, 08:21 | #14 (permalink) |
Member: 1441738 Status: Offline Sonork: shankar.anu200@!gmail.com Thanks Meter: 3 | Karbonn K9New ringer not working please hlp me bro. Karbonn k9New ringer not working ringer is ok ways is ok but ringer not working plese helpme bro... |
