Karbonn K9 White Display Solution. dear gsm forum member please solve my pro. thanks in advance |
Bro reball cpu solve your problem I am tested meny times |
Bro the display is getting white can u plz give the solution |
just change cpu.......................provlem solved 100% |
no need to change cpu or reball cpu just follow the below step for all type of chines follow the below steps for all type of chinese mobiles white lcd solution 100000000000000000 % working and 100000000 time tested ........... first of all resold it in good way if not work then remove camera and check if not work yet then remove lcd and check all track may one of the track is miss if any miss then make jumper and make it ok and check by pasting lcd if not working after that then you have to change lcd ......... regards........... |
Its impossible in mstar 8533c/85xx cpu... its some time work...if set is water damage... but mstar 8533c 90% cpu problem.. |
may be you are right Quote:
take display and heat mstar cpu frome down it will done 100% |
i offten just resold the display ,but if it goes white after few seconds you must change the display,if its white from the start resold it or flash the set ,sometimes change the big capacitors on the display strip |
new cpu plz Shop address.mobile Number.send k9 karbonn |
is it any lcd ic in karbon k9 mobile? or any china mobile ? if yes then plz guide me if anyone knows?????? |
Karbonn K9New ringer not working please hlp me bro. karbon k9new ringer not working please any solution bro... |
Karbonn K9New ringer not working please hlp me bro. Karbonn k9New ringer not working ringer is ok ways is ok but ringer not working plese helpme bro... |
pls help me k9 new ringer ic problem |
vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
