k9 ringer problem in karbon k9 there are no ringer ic If ringer not working plz reball cpu problem will solve 100% |
your r not a clear topic whot,s your phone condition ??? incomig or out going is ok or not?? that is ok so yo problam is lcd or lcd jack and not ok incoming outgoing so yo problam is system file corrupted so update your phone final is processor problam try cheng processor and solve |
karbonn k9 ringer problem slution 100% fitst chek track, meter red prob gnd black prob speakar tips two point then 500/700 ohms ,this ohms is not this mean foil open but both side ohms show means cpu problem rehot,reball,replace |
KARBONN K9 the display is getting white can u plz give the solution |
reheat / reball the cpu . that's it. |
please post with diagram the cpu of a china mobile bro. |
karbonn k9 no network problem solution plz give me bro |
bro change black colour coil in board solve by me |
karbonn k9 white lcd problem solve change cpu 100% done |
White Display Karbonn K9 White display....how to solved Give best way:rolleyes: |
Write S/W Version From IMEI Sticker. I Want To Know, Which CPU Inside Mstar Or MediaTek ? |
check the verson thers 2 versons check it |
k9 new ringer ic k9 ringer ic solution first of all check water damage around ic second check vbat connection to capacitor near ic third remove ic and solder properly and check ic points if all silver points ok then fix that ic itself no problem ringer for k9 new in other celis old w520 gfive mobile karbon kphone iphone look phone wing mobiles old and gfive w520 type any board |
Change power ic same MSW CPU problem solve |
