Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Karbonn > Karbonn Hardware Repair
Old 09-16-2012, 18:55   #1 (permalink)
Member: 1809324
Sonork: 100.1621044
Thanks Meter: 4
Karbonn K9 White Display Solution.
dear gsm forum member
please solve my pro.
thanks in advance
Old 09-17-2012, 17:04   #2 (permalink)
murari-GSM's Avatar
Member: 1538128
Sonork: 100.1613105
Thanks Meter: 196
Bro
reball cpu solve your problem
I am tested meny times
The Following User Says Thank You to murari-GSM For This Useful Post:
Old 03-09-2013, 14:06   #3 (permalink)
Member: 1893890
Bro
the display is getting white can u plz give the solution
Old 03-11-2013, 11:21   #4 (permalink)
shahadat87j's Avatar
Member: 1783085
Sonork: 100.1618518
Thanks Meter: 27
just change cpu.......................provlem solved 100%
Old 03-11-2013, 12:18   #5 (permalink)
Member: 1732000
Thanks Meter: 43
Old 03-12-2013, 11:43   #6 (permalink)
Member: 1891179
Sonork: 100.1627755
Thanks Meter: 50
no need to change cpu or reball cpu just follow the below step for all type of chines
follow the below steps for all type of chinese mobiles white lcd solution
100000000000000000 % working and 100000000 time tested ...........
first of all resold it in good way
if not work then remove camera and check
if not work yet then remove lcd and check all track may one of the track is miss if any miss then make jumper and make it ok and check by pasting lcd if not working after that
then you have to change lcd .........
regards...........
Old 03-12-2013, 20:22   #7 (permalink)
laxmi kamlesh's Avatar
Member: 1873645
Thanks Meter: 968
regards...........
Its impossible in mstar 8533c/85xx cpu...
its some time work...if set is water damage...
but mstar 8533c 90% cpu problem..
Old 03-13-2013, 08:06   #8 (permalink)
Member: 1891179
Sonork: 100.1627755
Thanks Meter: 50
Thumbs up may be you are right
but i solved several problem with this method and i am sure 90% will be sloved with this 10 % may be cpu problme
Old 03-19-2013, 14:39   #9 (permalink)
Member: 1903058
Sonork: harispk35
Thanks Meter: 8
take display and heat mstar cpu frome down it will done 100%
Old 03-29-2013, 21:34   #10 (permalink)
salim_belka2002's Avatar
Member: 64587
Thanks Meter: 36
i offten just resold the display ,but if it goes white after few seconds you must change the display,if its white from the start resold it or flash the set ,sometimes change the big capacitors on the display strip
Old 04-11-2013, 16:45   #11 (permalink)
gsmnitinmobile's Avatar
Member: 1595511
Sonork: nnn
Thanks Meter: 104
new cpu plz Shop address.mobile Number.send k9 karbonn
Old 04-15-2013, 07:50   #12 (permalink)
Member: 1616118
Sonork: sam ahmed
is it any lcd ic in karbon k9 mobile?
or any china mobile ?
if yes then plz guide me if anyone knows??????
Old 09-26-2013, 08:10   #13 (permalink)
Member: 1441738
Sonork: [email protected]!gmail.com
Thanks Meter: 3
Karbonn K9New ringer not working please hlp me bro.
karbon k9new ringer not working please any solution bro...
The Following User Says Thank You to shankar2000 For This Useful Post:
Old 09-26-2013, 08:21   #14 (permalink)
Member: 1441738
Thanks Meter: 3
Karbonn k9New ringer not working ringer is ok ways is ok but ringer not working plese helpme bro...
Old 10-07-2013, 16:27   #15 (permalink)
Member: 1739262
Thanks Meter: 9
pls help me k9 new ringer ic problem
Page generated in 0.33933 seconds with 7 queries
