Huawei Hardware Repair here you can get all the Hardware Repair information |
10-28-2016, 20:33 | #1 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2642407 Status: Offline Thanks Meter: 0 | Huawei g620s, memory card pinout Delivered it for repair, but they refused to repair it even if I paid So, my idea is to solder the micro SD card directly on the main board using 0,1mm wire from a coil Problem is, the memory card has 8 connectors, and the socket has 9. Top of mobile, backside of mobile up 1- 2- 3- 4- 5- 6- 7- 8- 9- The pins are not uniform, the middle ones are tighter grouped. Tried to soloder 1-8 to SC card, 9 to GND. Phone would not read the 16GM card. Card is OK, works in camera... tested it afterwards. I have a tiny soldering iron so no problem soldering the thin wire. I suspect some other pins are card detect? I do not have the socket anymore it was lost... Can anybody help? It's worth trying once more if I have the correct pinout. Then I can use the phone as before... please help... |
