Huawei Hardware Repair here you can get all the Hardware Repair information |
01-21-2015, 09:39 | #1 (permalink) |
Junior Member Join Date: Jan 2015 Location: abudhabi
Member: 2323994 Status: Offline Thanks Meter: 0 | Y530 charging problem I have a Huawei y530 charging problem pls help me I want schematic (charging section) if you havepls help me charging connector is OK I check it.. |
02-07-2015, 05:57 | #2 (permalink) |
Junior Member Join Date: Dec 2014 Location: kuwait
Member: 2320348 Status: Offline Thanks Meter: 0 | if u had sent the pcb pic it would have been better normally in huawei y500 series there will be a transister (3leg ic .some say ) near battery terminal .. just connect charging cable and short the transistor (pnp juntion diode) . or remove that transistor and insert charging connector n short it .. and again re solder it should work.. try it.. may be useful.. it worked for me for y511 and others but i dint tried for 530.. ! |
