Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 07-29-2014, 08:25   #1 (permalink)
Member: 1599031
error 4013 iphone 5c
how to solved erreur 4013 iphone5c restauration 7.1.2
new battery new cable
thank
Old 07-29-2014, 08:44   #2 (permalink)
Member: 1599031
you know please help
Old 07-29-2014, 09:05   #3 (permalink)
Super Moderator
mihut's Avatar
Member: 824
Thanks Meter: 25,151
PC Chang then try
Your problem solved 100%
Be,
Mihut
The Following User Says Thank You to mihut For This Useful Post:
Old 07-29-2014, 10:42   #4 (permalink)
Member: 1599031
Originally Posted by mihut View Post
PC Chang then try
Be,
Mihut
replacement pc without the other way he
Old 07-30-2014, 05:49   #5 (permalink)
Member: 1599031
Old 07-31-2014, 02:55   #6 (permalink)
Member: 1599031
We wish you help by.....................
Old 08-04-2014, 16:03   #7 (permalink)
Member: 2234335
Where do you see number of error? What else is written? Did you try to make restart?)
Old 04-22-2015, 16:58   #8 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
iphone 5c 4013 error.i changed pc ,cable but same problem...plz help me
Old 06-01-2015, 17:07   #9 (permalink)
Member: 2194181
Try to resolder the commpas ic
Old 06-05-2015, 02:25   #10 (permalink)
Member: 2398349
Thanks Meter: 62
sometimes it happens wen u use a after market part on the phone. open the phone and check what had been changed. change it back with the original part, u'll be just fine. the most common part for this error is the screen or sensor. so restore the phone without screen or sensor to see if its working or not and let me know!!
Old 08-11-2015, 13:44   #11 (permalink)
Member: 2207038
Thanks Meter: 2
HI
FIRST REMOVE ALL PARTS FROM PCB TRY TO RESTORE SOFTWARE
IF NOT WORKING CLEAN FULL PCB AND HEAT commpas ic THAN RESTORE SOFTWARE
Old 08-26-2015, 14:47   #12 (permalink)
Member: 909147
Thanks Meter: 9
I did have this error with an iphone 5s where the baseband ic was changed or look for an short on the motherboard
Old 08-29-2015, 10:13   #13 (permalink)
Member: 1813698
Thanks Meter: 8
sir look for water damage
and take out all parts ( camera - front camera - ... )
try restore
Page generated in 0.23112 seconds with 8 queries
