09-05-2017, 06:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2737783 Status: Offline Thanks Meter: 39 | How to Check If iPhone Is Locked or Unlocked? Step1: You need to get your iPhone’s IMEI. Go to Settings app, click General -> About -> scroll down to find the IMEI and write it down. Or, you can directly use 3uTools to get your iPhone’s IMEI. Connect your iPhone to 3uTools, as shown below, put the mouse arrow on IMEI, click it then IMEI will be copied. Step2: Go to this web http://****************, then enter / paste iPhone’s IMEI here. Step3: Then you’ll see the item SIM Lock at the bottom of those info. If it shows Unlocked, that means your iPhone has no carrier/ network lock. While if it shows locked, your iPhone can only be used with SIM cards from that specific carrier/network. |
The Following User Says Thank You to TGB For This Useful Post: |
09-05-2017, 06:55 | #2 (permalink) |
Member: 2737783 Status: Offline Thanks Meter: 39 | This tutorial is for you to check if your iDevice has carrier lock, if you have an double, you may leave your comment here. They I will reply you as soon as possible. You may follow 3uTools on Twitter: https://twitter.com/3u_tools, thnak you for the support. |
