Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 12-25-2017, 09:58   #1 (permalink)
Member: 2494453
Thanks Meter: 200
Wink How to jailbreak iPhone 5/5c on iOS 10.3.3
How to Jailbreak iOS 10.3.3 Using H3lix?
Here’s how to jailbreak iOS 10.3.3 using h3lix semi-untethered jailbreak on 32-bit iDevices. And please stay tuned for 3uTools support.
As you may already know by now, the first public iOS 10.3.3 jailbreak h3lix is now available to download. It’s important to note that this 32-bit jailbreak is semi-untethered in nature, which means you will need to put your device into jailbreak mode after every reboot.
Compatibility
Device
iPhone 5
iPhone 5c
iPad (4th generation)
Firmware
This is a universal jailbreak and supports all versions starting from iOS 10 to 10.3.3. But according to some testing results, this jailbreak only works on iOS 10.3.3.
Operations
Step 1: Download h3lix jailbreak for 32-bit iOS 10.3.3 devices from here: RC 1 (official)
Step 2: Download Cydia Impactor for Windows or Mac from cydiaimpactor.com.
Step 3: Restore your device to iOS 10.3.3 using 3uTools if you haven’t already. We recommend doing this as it’s always great to start afresh when jailbreaking to avoid any issues. Make sure you backup your device’s data though before doing this.
Step 4: Connect your iOS device to your computer via USB and then launch Cydia Impactor.
Step 5: Sideload the jailbreak IPA using Cydia Impactor.
Step 6: Once sideloaded and the profile has been trusted, launch the h3lix jailbreak app.
Step 7: Press the “jailbreak” button in the center and wait for the jailbreak to do its thing.
Step 8: Once done, you should have Cydia on the Home screen of your device.
Step 9: After respring, you should be back into jailbreak mode, able to run Cydia and install tweaks.
Check original post on 3uTools
Old 01-03-2018, 22:31   #2 (permalink)
Member: 2391058
Thanks Meter: 2
very good contribution, is very helpful
Old 01-04-2018, 09:09   #3 (permalink)
Member: 2494453
Thanks Meter: 200
You could try to use 3uTools to manage your iPhone
Old 01-05-2018, 05:39   #4 (permalink)
Member: 2450808
thanks so much
tested on iPhone 5
100% worked and my iPhone 5 is now jailbroken
real thanks to you and who did make the jailbreak possible
Old 01-06-2018, 03:06   #5 (permalink)
Member: 2450808
im just back to say on my iPhone if you turnned of the pgone and turnned it back on the Jailbreak apps will be off until you start h3lix again
not sure if this only or what but this what i have for now
Old 02-07-2018, 15:40   #6 (permalink)
Member: 2808685
Supported 11.3 latest?
Page generated in 0.13166 seconds with 8 queries
