Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 07-23-2014, 09:19   #1 (permalink)
Member: 918393
Thanks Meter: 515
iCloud Activation process intercepted successfully
Hi guys!
i've managed to compare activations infos in 2 cases
1- in case where iDevice not linked to an Apple ID
2- in case where iDevice is linked to an Apple ID
& compare results between my local bypass server & real apple server, & found a lot of thing changed in activations process & encryptions, doulCi have new exploit but he can't to make it public because apple will patch it as his previous exploit who stopped working 2 months ago duo to SSL-FIX, but i tell you one thing , is still possible to bypass again.
testing iPad wifi bypass with local server & appple server to find the changes:
The Following 15 Users Say Thank You to m-fodil For This Useful Post:
Old 07-23-2014, 10:48   #2 (permalink)
Member: 345732
Thanks Meter: 16
Is it still possible to bypass the iPad wifi?
Old 07-23-2014, 13:29   #3 (permalink)
Gecko_UK's Avatar
Member: 961957
Sonork: Jabber: [email protected]
Thanks Meter: 641
You are not going to bypass now with acunetix and fiddler
Old 07-23-2014, 14:50   #4 (permalink)
Member: 2209517
Thanks Meter: 134
Possible explain more
Old 07-23-2014, 15:24   #5 (permalink)
Member: 1393993
did u bypass yo icloud
Old 07-23-2014, 17:50   #6 (permalink)
Member: 918393
Thanks Meter: 515
i did not say i bypassed this iPad , even i had a working local bypass server before apple patch the SSL-bug (server-side)
now i'm only doing some test & infos gathering To compare the results because now my main problem not (privet_key) but the (FairPlayKeyData)
now i have to know how to create FairePlayKeyData for every iDevice connected to my local server & i know that FairePlayKeyData generated in device and not on server
The Following 4 Users Say Thank You to m-fodil For This Useful Post:
Old 07-23-2014, 19:37   #7 (permalink)
Gecko_UK's Avatar
Member: 961957
Thanks Meter: 641
I had made a local activator too.
can't see any sense why you are trying to compute valid FairPlay data still?
maybe you should spend the time to research a non server-based bypass while everyone else is wasting time staring at packet captures
Old 07-23-2014, 20:17   #8 (permalink)
headszone1's Avatar
Member: 1568769
Sonork: 161.1167
Thanks Meter: 208
gecko uk can you bypass icloud
Old 07-23-2014, 20:41   #9 (permalink)
Member: 918393
Thanks Meter: 515
1st: show device infos & state before activations???
2nd: if you use Activator then why iTunes is opened???
The Following User Says Thank You to m-fodil For This Useful Post:
Old 07-24-2014, 01:35   #10 (permalink)
Member: 345732
Thanks Meter: 16
Question
I'm gonna ask the same question again, Is it still possible to bypass the iPad wifi?
The Following User Says Thank You to habibtomb For This Useful Post:
Old 07-24-2014, 03:08   #11 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 309
Hi Gecko UK , thats nice, can we make backup of activation ticket (jailbreak SHH) and restore to device whit your software??
The Following User Says Thank You to bananin For This Useful Post:
Old 07-24-2014, 03:53   #12 (permalink)
Member: 918393
Thanks Meter: 515
Gecko UK:
ohhhhhhhhh, just now saw the second picture
your iPhone Version is 6.1????? but iCloud lock come with IOS7!!
The Following 2 Users Say Thank You to m-fodil For This Useful Post:
Old 07-24-2014, 04:05   #13 (permalink)
Member: 918393
Thanks Meter: 515
at moment no, because activation process changed and exactly in FairPlayKeyData , but if we solve this problem then all devices can be activated
Old 07-24-2014, 05:11   #14 (permalink)
Cheater -Don't Deal with him-
Member: 743601
Sonork: 83392409
Thanks Meter: 138
hi gecko can i have your smoky?
Old 07-24-2014, 06:15   #15 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 127
post download link
if you have it
The Following User Says Thank You to duncan99 For This Useful Post:
Page generated in 0.24190 seconds with 9 queries
