07-23-2014, 09:19 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Algeria
Member: 918393 Status: Offline Thanks Meter: 515 | iCloud Activation process intercepted successfully i've managed to compare activations infos in 2 cases 1- in case where iDevice not linked to an Apple ID 2- in case where iDevice is linked to an Apple ID & compare results between my local bypass server & real apple server, & found a lot of thing changed in activations process & encryptions, doulCi have new exploit but he can't to make it public because apple will patch it as his previous exploit who stopped working 2 months ago duo to SSL-FIX, but i tell you one thing , is still possible to bypass again. testing iPad wifi bypass with local server & appple server to find the changes: |
The Following 15 Users Say Thank You to m-fodil For This Useful Post: |
07-23-2014, 13:29 | #3 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | You are not going to bypass now with acunetix and fiddler |
07-23-2014, 17:50 | #6 (permalink) |
Member: 918393 Status: Offline Thanks Meter: 515 | i did not say i bypassed this iPad , even i had a working local bypass server before apple patch the SSL-bug (server-side) now i'm only doing some test & infos gathering To compare the results because now my main problem not (privet_key) but the (FairPlayKeyData) now i have to know how to create FairePlayKeyData for every iDevice connected to my local server & i know that FairePlayKeyData generated in device and not on server Last edited by m-fodil; 07-23-2014 at 17:59. |
The Following 4 Users Say Thank You to m-fodil For This Useful Post: |
07-23-2014, 19:37 | #7 (permalink) | |
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Quote:
can't see any sense why you are trying to compute valid FairPlay data still? maybe you should spend the time to research a non server-based bypass while everyone else is wasting time staring at packet captures | |
07-23-2014, 20:41 | #9 (permalink) | |
Member: 918393 Status: Offline Thanks Meter: 515 | Quote: 2nd: if you use Activator then why iTunes is opened??? Last edited by m-fodil; 07-23-2014 at 20:46. | |
The Following User Says Thank You to m-fodil For This Useful Post: |
07-24-2014, 03:08 | #11 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Hi Gecko UK , thats nice, can we make backup of activation ticket (jailbreak SHH) and restore to device whit your software?? |
The Following User Says Thank You to bananin For This Useful Post: |
