Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 07-25-2014, 18:54   #31 (permalink)
Member: 918393
Thanks Meter: 515
Gecko_UK: i'm not wrong if i say the main problme is the FairPlayKeyData, and just discovered the reason why it's not computed, simply because the FairPlayCertChain was expired, 2 month ago & before apple patch doulCi server , this certchain work even expired when we accept warning alert in activation process, okay i'll solve this problem soon & server will be 100/100 fonctional
Old 07-25-2014, 18:55   #32 (permalink)
Member: 918393
Thanks Meter: 515
Gecko_UK: activation_record.plist must contain FairPlayKeyData
<dict>
<key>AccountToken</key>
<data>'.$accountTokenBase64.'</data>
<key>AccountTokenCertificate</key>
<data>'.$accountTokenCertificate.'</data>
<key>AccountTokenSignature</key>
<data>'.$accountTokenSignature.'</data>
<key>DeviceCertificate</key>
<data>'.$deviceCertificate.'</data>
<key>FairPlayKeyData</key>
<data>'.$fairPlayKeyData.'</data>
<key>LDActivationVersion</key>
<integer>2</integer>
</dict>
</plist>
Old 07-25-2014, 19:31   #33 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 309
My ipad hacktivate have expiration till 2015
Old 07-25-2014, 19:40   #34 (permalink)
Member: 918393
Thanks Meter: 515
Thanks For report
The Following User Says Thank You to m-fodil For This Useful Post:
Old 07-26-2014, 03:49   #35 (permalink)
Gecko_UK's Avatar
Member: 961957
Sonork: Jabber: [email protected]
Thanks Meter: 641
@m-fodil sure it's not tricky to inject your own own text or popup on activation screen..but how will you crash setup.app?..A proper crash will give you ability to execute own code from userland, very difficult these days- even iOS 5 it was not easy.. otherwise you just hide temporarily, it's not useful and comes with other problems. Of course you cannot jailbreak after on unactivated device simply as you wrote. if you have useful mobilesafari crash you can make six figures no problem selling your exploit , anyway you are wasting your time chasing the fairplay stuff..as you said before the method used to bypass is not important; so why not search for non-server based solution while everyone is fruitlessly copying and pasting leaked tidbits of code
@griff26 About the lockdown and modem activation, you can bring it online only in select cases, like when you have cached data. Anyone who claim they can give cell service to any icloud locked handset without actually disabling FMiP lock server side will only ever show limited demo and give excuses, they know not possible to do on all devices-- but they can get some extra twitter followers and ad earnings for claiming otherwise
The Following 4 Users Say Thank You to Gecko_UK For This Useful Post:
Old 07-26-2014, 05:45   #36 (permalink)
Member: 918393
Thanks Meter: 515
in simple word setup.app can be easily crashed & mobilesafari crash can't be used to escape FMI
Old 07-26-2014, 07:25   #37 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 166
he was the one who gave the info
to bypass iCloud
that merruk, aqua and mina
viewed as making tranabaja in php
is otherwise
but this was the beginning
is it old
r0bf0rdsn0w
Old 07-26-2014, 14:34   #38 (permalink)
Gecko_UK's Avatar
Member: 961957
Thanks Meter: 641
@m-fodil
any webkit bugs which worked against mobilesafari will work for purplebuddy too. But you are right, nobody is bypassing
FMiP lock like that, or they are a genius if they can
although this crash report not symbolicated, no stack trace. generally SIGABRT exception is not useful at all, to research
userland crash better to attach to gdb process on a jb device but it's almost a dead end chasing that approach nowadays
Old 07-27-2014, 07:46   #39 (permalink)
Member: 918393
Thanks Meter: 515
@Gecko_UK:
this is how i can crash setup , sometimes iDevice not respond to the crash, need retrying 5 or 6 times, sometimes when crashing Device disconnected from wifi, boot loop, return to activation screen...but the essential thing is that method work
Old 07-27-2014, 14:55   #40 (permalink)
Member: 1539068
Thanks Meter: 74
icloud bypass
how to use 'r0bf0rdsn0w', i have already downloaded the software, but it doesn't work, i have followed the instruction but still getting error.. parameter is incorrect..
can someone explain it to me how to use it properly.. thanks..
Old 07-27-2014, 16:06   #41 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
Can we hide some data from apple server when in activation process?
B.R.
Old 07-27-2014, 19:26   #42 (permalink)
Member: 1456415
Sonork: 23401
where can i download it
Old 07-28-2014, 22:47   #43 (permalink)
Member: 61751
Thanks Meter: 14
download link
post download link
Old 07-28-2014, 23:18   #44 (permalink)
Member: 1539068
Thanks Meter: 74
there are many links available to download..
r0bf0rdsn0w
or
iCloud removal trusted solution-r0bf0rdsn0w code and method of use
The Following User Says Thank You to mobileplus21 For This Useful Post:
Old 07-29-2014, 08:04   #45 (permalink)
andreiza's Avatar
Member: 793212
Thanks Meter: 29
Originally Posted by mobileplus21 View Post
password? .........................
The Following User Says Thank You to andreiza For This Useful Post:
Page generated in 0.28822 seconds with 9 queries
