07-25-2014, 18:54 | #31 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Algeria
Member: 918393 Status: Offline Thanks Meter: 515 | |
07-25-2014, 18:55 | #32 (permalink) |
Member: 918393 Status: Offline Thanks Meter: 515 | Gecko_UK: activation_record.plist must contain FairPlayKeyData <dict> <key>AccountToken</key> <data>'.$accountTokenBase64.'</data> <key>AccountTokenCertificate</key> <data>'.$accountTokenCertificate.'</data> <key>AccountTokenSignature</key> <data>'.$accountTokenSignature.'</data> <key>DeviceCertificate</key> <data>'.$deviceCertificate.'</data> <key>FairPlayKeyData</key> <data>'.$fairPlayKeyData.'</data> <key>LDActivationVersion</key> <integer>2</integer> </dict> </plist> Last edited by m-fodil; 07-25-2014 at 19:03. |
07-26-2014, 03:49 | #35 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | @m-fodil sure it's not tricky to inject your own own text or popup on activation screen..but how will you crash setup.app?..A proper crash will give you ability to execute own code from userland, very difficult these days- even iOS 5 it was not easy.. otherwise you just hide temporarily, it's not useful and comes with other problems. Of course you cannot jailbreak after on unactivated device simply as you wrote. if you have useful mobilesafari crash you can make six figures no problem selling your exploit , anyway you are wasting your time chasing the fairplay stuff..as you said before the method used to bypass is not important; so why not search for non-server based solution while everyone is fruitlessly copying and pasting leaked tidbits of code @griff26 About the lockdown and modem activation, you can bring it online only in select cases, like when you have cached data. Anyone who claim they can give cell service to any icloud locked handset without actually disabling FMiP lock server side will only ever show limited demo and give excuses, they know not possible to do on all devices-- but they can get some extra twitter followers and ad earnings for claiming otherwise |
The Following 4 Users Say Thank You to Gecko_UK For This Useful Post: |
07-26-2014, 05:45 | #36 (permalink) | |
Member: 918393 Status: Offline Thanks Meter: 515 | Quote:
The Following User Says Thank You to m-fodil For This Useful Post: |
07-26-2014, 07:25 | #37 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | he was the one who gave the info to bypass iCloud that merruk, aqua and mina viewed as making tranabaja in php is otherwise but this was the beginning is it old r0bf0rdsn0w |
07-26-2014, 14:34 | #38 (permalink) |
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | @m-fodil any webkit bugs which worked against mobilesafari will work for purplebuddy too. But you are right, nobody is bypassing FMiP lock like that, or they are a genius if they can although this crash report not symbolicated, no stack trace. generally SIGABRT exception is not useful at all, to research userland crash better to attach to gdb process on a jb device but it's almost a dead end chasing that approach nowadays |
07-27-2014, 07:46 | #39 (permalink) |
Member: 918393 Status: Offline Thanks Meter: 515 | @Gecko_UK: this is how i can crash setup , sometimes iDevice not respond to the crash, need retrying 5 or 6 times, sometimes when crashing Device disconnected from wifi, boot loop, return to activation screen...but the essential thing is that method work |
07-27-2014, 14:55 | #40 (permalink) |
Banned Join Date: Mar 2011
Member: 1539068 Status: Offline Thanks Meter: 74 | icloud bypass how to use 'r0bf0rdsn0w', i have already downloaded the software, but it doesn't work, i have followed the instruction but still getting error.. parameter is incorrect.. can someone explain it to me how to use it properly.. thanks.. |
07-28-2014, 23:18 | #44 (permalink) |
Member: 1539068 Status: Offline Thanks Meter: 74 | there are many links available to download.. r0bf0rdsn0w or iCloud removal trusted solution-r0bf0rdsn0w code and method of use |
The Following User Says Thank You to mobileplus21 For This Useful Post: |
07-29-2014, 08:04 | #45 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: Bali
Member: 793212 Status: Offline Thanks Meter: 29 | Quote:
password? ......................... | |
The Following User Says Thank You to andreiza For This Useful Post: |
