08-18-2014, 12:41 | #62 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Algeria
Member: 918393 Status: Offline Thanks Meter: 515 | @rogerboogie: Using Self-Signed Cert, but not easy at all, because for every iDevice you want to activate you must chage many things |
The Following User Says Thank You to m-fodil For This Useful Post: |
08-20-2014, 07:13 | #70 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | Quote:
as i can see on your debug process , you generate data for each device using serial number as identificator i think certs to activate device are ok but the inyection method for each device are the point i have my local server with the index working mounted ssl server with self signed certs ,but the bypass only happend on itunes and cannot synch with device can you talk more about your method, here or in private , i really apreciate if you can explain about the process br roger | |
08-20-2014, 12:15 | #71 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2205020 Status: Offline Thanks Meter: 0 | m-fodil What exactly did you do there?..because i can only see you scanning albert server with Kali and Nmap... i am also trying to find some working iCloud bypass...tried many things but to no good |
08-23-2014, 16:16 | #72 (permalink) |
Member: 918393 Status: Offline Thanks Meter: 515 | trying to bypass via crashing setup application, and iPhone totaly compromised: https://www.youtube.com/watch?v=DV6i98eLiWM |
08-24-2014, 03:55 | #73 (permalink) |
Freak Poster Join Date: Feb 2010 Location: MAYARI,HLG,CUBA
Member: 1229493 Status: Offline Sonork: 100.1636711 Thanks Meter: 70 | here How To Unlock Activation Lock iPhone is an video with a hack for bypass icloud activation, but I donīt know if working, please someone test it |
