Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 02-21-2016, 15:08   #16 (permalink)
Member: 1620670
error 48
I have the same problem please help
Old 02-27-2016, 09:20   #17 (permalink)
Member: 117312
Thanks Meter: 6
I have the same problem pls help
Old 02-29-2016, 22:08   #18 (permalink)
Member: 1402834
I am warmed by phone hair dryer about half an hour during the installation and be all O.K.
If you do not pass at first, repeat the process.
Old 03-07-2016, 18:59   #19 (permalink)
Member: 2542510
Kameni_38
hello,
did you update your itunes to its latest version.
compatible to your bit and windows
iPhone6,2_9.2.1_13D15_Restore (1)
Old 03-07-2016, 19:15   #20 (permalink)
Member: 2542510
Sunny
update or dl itunes compatible to pc windows.
dfu mode. restore iphone.
Old 10-22-2016, 07:09   #21 (permalink)
Member: 2584310
Thanks Meter: 2
error 48
i have also iphone 5,same problem error 48..there's any one who can help us with this problem???thanks
Old 10-22-2016, 14:17   #22 (permalink)
mrfhassanlk's Avatar
Member: 1075753
Thanks Meter: 66
I had the error 50 so i reheated the Baseband chip now it it comes error 48.
two times i tried same thing. I am going to restore it through a mac and see if it restores and keep you posted.
Old 10-27-2016, 00:03   #23 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Error 48 is a problem with the baseband ic. You can try to replace the rf power manager.
Old 12-29-2016, 16:05   #24 (permalink)
Member: 1705566
Thanks Meter: 9
iphone 5 restore error48...................pls help
Old 01-14-2017, 11:52   #25 (permalink)
Member: 1460827
error 48 for iPhone 5g, u can try to change U601_Rf,
Old 01-25-2017, 16:40   #26 (permalink)
Member: 2553311
Thanks Meter: 6
Try restoring the logic board with only the batery, an ORIGINAL display and charge flex connected to it.
Worked for me as I was Trying to restore an iPhone 6, but then it started to reboot ramdonly, changed the battery afterward and then worked again.
Old 02-10-2017, 20:48   #27 (permalink)
Member: 1388233
Thanks Meter: 7
Do you fix the this issue?
Old 04-13-2017, 12:04   #28 (permalink)
Member: 540856
Thanks Meter: 14
try to reball baseband ic
Old 01-13-2019, 09:59   #29 (permalink)
Member: 2880877
Cool for iphone 5 48 error
change baseband ic then try to flash only update
Page generated in 0.21123 seconds with 8 queries
