iphone 5 error 1669 iphone 5 upgrade error 1669 i0s7 cable hanging discs I tried every way are not known please help me |
Not my solution i am having same problem, here is what i have found, testing right now. Delete the iOS 6 IPSW as you won't be able to use it again. Uninstall iTunes 11.1 and all of its cache (make sure you remove the cache). Restart your PC if prompted to. Then reinstall a copy of iTunes 11.0.5 from the direct links below. If you have any libraries or locally cached data that you want to keep, temporarily store them somewhere until you get the situation fixed Mac OSX: https://secure-appldnld.apple.com/iT...unes11.0.5.dmg Windows 32 Bit: https://secure-appldnld.apple.com/iT...TunesSetup.exe Windows 64 Bit: https://secure-appldnld.apple.com/iT...nes64Setup.exe Thanks to willerz2 |
me installed itunes 10.5 but could not open to be that require right to install the new version now me not a process |
Try another PC then DFU first your iphone and restore. |
I've put in dfu mode and restore but the results carried bugs 1 |
not itunes 10.5, but 11.0 series, previous one, before latest 11.1 take care to details..than or find another pc with 11.0, cause its always mess when unistalling itunes.. |
when I restore in itunes less than half the distance of the first error, and error 1669 itunes 11.1 hours to handle stars? |
same problem here! only restore to iOS 7, now stucked at recover error 1669! tried 3 versions of itunes on 1 laptop, 1 desktop 1 iMac |
Brother, First. last version itunes. Second: try to restore ios7 with original usb cable don't use usb Hub. |
rebool U501_rf. my problem solved. |
please help us... |
after rebool u501. open itunes restore again. |
how long to heat u501 and at what temp?? |
this error U601_RF made me and changed it is ok |
Anyone have solid solution? what does "this error U601_RF made me and changed it is ok" mean? |
