Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 09-24-2013, 06:45   #1 (permalink)
Member: 835660
iphone 5 error 1669
iphone 5 upgrade error 1669 i0s7 cable hanging discs I tried every way are not known please help me
Old 09-24-2013, 22:54   #2 (permalink)
Member: 899017
Not my solution
i am having same problem, here is what i have found, testing right now.
Delete the iOS 6 IPSW as you won't be able to use it again.
Uninstall iTunes 11.1 and all of its cache (make sure you remove the cache). Restart your PC if prompted to. Then reinstall a copy of iTunes 11.0.5 from the direct links below. If you have any libraries or locally cached data that you want to keep, temporarily store them somewhere until you get the situation fixed
Mac OSX: https://secure-appldnld.apple.com/iT...unes11.0.5.dmg
Windows 32 Bit: https://secure-appldnld.apple.com/iT...TunesSetup.exe
Windows 64 Bit: https://secure-appldnld.apple.com/iT...nes64Setup.exe
Thanks to willerz2
Old 09-25-2013, 05:20   #3 (permalink)
Member: 835660
me installed itunes 10.5 but could not open to be that require right to install the new version now me not a process
Old 09-25-2013, 05:41   #4 (permalink)
Member: 1528324
Sonork: none
Thanks Meter: 9
Try another PC then DFU first your iphone and restore.
The Following User Says Thank You to GSMnoel For This Useful Post:
Old 09-25-2013, 08:52   #5 (permalink)
Member: 835660
I've put in dfu mode and restore but the results carried bugs 1
Old 09-25-2013, 09:07   #6 (permalink)
cobra iphoni's Avatar
Member: 1744389
Sonork: 100.1657056
Thanks Meter: 215
not itunes 10.5, but 11.0 series, previous one, before latest 11.1
take care to details..than
or find another pc with 11.0, cause its always mess when unistalling itunes..
Old 09-25-2013, 11:32   #7 (permalink)
Member: 835660
when I restore in itunes less than half the distance of the first error, and error 1669 itunes 11.1 hours to handle stars?
Old 10-07-2013, 15:30   #8 (permalink)
johnkill's Avatar
Member: 49226
Thanks Meter: 9
same problem here!
only restore to iOS 7, now stucked at recover error 1669!
tried 3 versions of itunes on 1 laptop, 1 desktop 1 iMac
Old 10-10-2013, 18:17   #9 (permalink)
Shahin Hasan's Avatar
Member: 1529244
Sonork: 1720
Thanks Meter: 150
Brother,
First. last version itunes.
Second: try to restore ios7 with original usb cable don't use usb Hub.
Old 11-20-2013, 00:14   #10 (permalink)
Member: 622715
Thanks Meter: 82
rebool U501_rf. my problem solved.
Old 11-21-2013, 19:06   #11 (permalink)
Member: 1288185
Thanks Meter: 74
how you solved your problem...
please help us...
Old 11-22-2013, 22:02   #12 (permalink)
Member: 622715
Thanks Meter: 82
after rebool u501. open itunes restore again.
Old 11-26-2013, 00:13   #13 (permalink)
Member: 82807
Thanks Meter: 18
how long to heat u501 and at what temp??
Old 11-26-2013, 11:40   #14 (permalink)
Member: 2052066
this error U601_RF made ​​me and changed it is ok
Old 11-26-2013, 22:44   #15 (permalink)
Member: 2069573
Anyone have solid solution? what does "this error U601_RF made ​​me and changed it is ok" mean?
Page generated in 0.34640 seconds with 8 queries
