10-18-2014, 08:17 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Novo
Member: 177503 Status: Offline Sonork: 100.1657346 Thanks Meter: 390 | insert phone in DFU mode and make update online Code: Error 27 modified the restore.plist so it would flash and also exchanged RestoreRamDisk and kernelcache. restore the original iOS. |
10-18-2014, 09:09 | #4 (permalink) | |
Member: 177503 Status: Offline Sonork: 100.1657346 Thanks Meter: 390 | Quote:
turn of the device, while its powered off press home button and connect usb cable. keep home button press untill it detects in itunes. then restore in itunes online | |
03-21-2016, 11:49 | #12 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2224244 Status: Offline Thanks Meter: 2 | hello to all members i got a iphone 6 with error 27 after a lot of proves that i have done this error is occured when you change display and the stripes are not connected good. so all you have to do is to clean them and remount display than try a fresh restore. IMPORTANT: it might also be the problem of screws. take a look at them. this problem also requires a genuine battery of iphone. i got it from another iphone 6. good luck. hope i helped. |
03-30-2017, 15:52 | #13 (permalink) |
Crazy Poster Join Date: Jul 2015 Location: Italy
Member: 2426290 Status: Offline Thanks Meter: 19 | Hello, I have encountered this problem when a iphone 5 did not detect the battery, I connected direct feeding with bench supply and is equal, it would seem that the problem is the ic u2 as iphone 5 turns on and turns off immediately, I run lightweight reflw via weller wha-2000 220 degrees and 260 degrees and subsequently wds620 seemed to want to leave but instead remains the error, I believe it to be replaced u2 ic |
