09-09-2015, 21:02 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Romania
Member: 2332708 Status: Offline Thanks Meter: 7 | Iphone 5s error 52 itunes restore I changed cable not from him I tried windows 7 and windows 8.1 1. Press Windows Key + C. 2. The Charms Bar will open. 3. Click the Settings icon. 4. Click Control Panel. 5. Click Programs icon, and then Programs and Features. 6. Is there any program entry of iTunes software? If no, download a fresh setuphere and install the program. After successful installation restart your machine. If it is already installed, right click the program entry, select Uninstall. Follow the wizard, reboot the laptop and then reinstall it again. For Earlier Versions of Windows: 1. Click the Start button. 2. Type “Uninstall a program” in the Search Box. 3. Press ENTER. 4. Refer Steps # 6 from Windows 8.1/ 8 user’s paragraph. Delete Upper & Lower Filters Upper and Lower filters are the strings in your Windows Registry. In order to avoid error 52 when connecting iPhone 5 to Windows laptop through USB, delete the upper and lower filters. For Windows 8.1/ 8: 1. Press the Windows Key. 2. Type “RegEdit” in the Search Box. 3. Click the Apps icon. 4. Open that from the Search Results. 5. Registry Editor will open. 6. Locate the following Registry path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{36FC9E60-C465-11CF-8056-444553540000} 7. Right click a string called “UpperFilters” and select Delete option from the context menu. Click OK in the new confirmation pop up. 8. Locate the following Registry path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{36FC9E60-C465-11CF-8056-444553540000} 9. Right click a string called “LowerFilters” and select Delete option from the context menu. Click OK in the new confirmation pop up. 10. Exit Registry Editor window. Reboot your laptop. For Earlier Versions of Windows: 1. Click the Start button. 2. Select Run. 3. Type “RegEdit” in the Open textbox. 4. Press ENTER. 5. Refer Steps # 6-9 from Windows 8.1/ 8 user’s paragraph. Uninstall and Reinstall the Drivers Sometimes problem with the driver causes your laptop to display an error. Uninstall the driver, unplug iTunes device, reinstall the driver and then reboot your machine. This may prevent reoccurrence of the error. For Windows 8.1/ 8: 1. Press Windows Key + X. 2. Click Device Manager. 3. Expand the top root. 4. Locate and right-click the iTunes device displayed in the left panel. 5. Select Properties. 6. Click the Driver tab, and then Uninstall button. 7. Disconnect your iTunes device. 8. Complete the removal wizard, and then reboot the laptop. 9. After your laptop turns on, refer Steps # 1-3. 10. Right-click the top node, select Scan for hardware changes. 11. Once again you’ll have to reboot the laptop in order to complete the installation process. not working |
01-04-2016, 20:02 | #2 (permalink) |
Freak Poster Join Date: Jan 2013 Location: RUSSIA
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Nobody has ever found a solution to this matter? After all this i even changed battery and still the firmware writens till 99% and stops there! error 52 |
08-14-2016, 03:35 | #4 (permalink) |
Junior Member Join Date: May 2014
Member: 2182772 Status: Offline Thanks Meter: 0 | Hi guys! Search for "Error 52 - Many are having this issue, but there is no fix" on Reddit. Trying to gather everyone having the error 52 issue into one place so that apple can try to do something about it. Don't forget to comment and upvote! |
08-14-2016, 03:35 | #5 (permalink) |
