03-02-2014, 13:22 | #21 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 363949 Status: Offline Thanks Meter: 24 | 4005 error iphone 5s still not done anybody with the sucess pls post the results i m too stuck over here cant restore in any mode dfu failed recovery failed i think its hardware issue for sure |
The Following User Says Thank You to nirav000 For This Useful Post: |
07-02-2014, 19:25 | #24 (permalink) |
Freak Poster Join Date: Mar 2008 Location: (•,•)
Member: 727850 Status: Offline Sonork: 100.1625445 Thanks Meter: 3 | If you are facing iTunes error 1669 on iPhone, you might be having some hardware issues: 1. In case you water is spilled over your device it is prone to suffer from 1669. However, water damage can be judged by a tiny red dot on the screen. In case you have spilled water over, it we suggest you to switch it off immediately to avoid further damage and take it to the nearest repair shop. |
