08-23-2014, 19:52 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 619497 Status: Offline Thanks Meter: 1 | Iphone 5 GSM water damaged error 4005 boot loop I bought a water dameged Iphone 5, cleaned it thoroughly with IPA after removing the shields and put a new battery in it. Now it`s stuck in boot loop...5 seconds Apple, then dark and so on. When I hold the home button while putting it in USB it goes into recovery. I am able to get into DFU, but in the end it always ends up in Error 4005 , itunes keeps waiting on the Iphone and the phone is in the loop mentioned before. I tried 2 different new batteries, getting new docks next week, but I`m afraid it has to do something with hardware, tried 4 different computers also. Anyone another idea about this, please Still hoping it will work in the end to give it to my daughter |
The Following User Says Thank You to wynand2000 For This Useful Post: |
08-23-2014, 21:20 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Novo
Member: 177503 Status: Offline Sonork: 100.1657346 Thanks Meter: 390 | @wynand2000 mate, until u got new docks u better check few things. 1. make sure u are using original USB cable 2. make sure itunes is up-to-date 3. not using any USB HUB. plug the cable straight to the USB ports that's connected directly to Main board. i wish ur daughter gets her iphone real soon |
08-23-2014, 23:18 | #3 (permalink) |
Member: 619497 Status: Offline Thanks Meter: 1 | Hi String Master, thanks for respond! 1: Usb cable is original 2: Itunes is up to date 3: I tried different computers , also in the rear USB which is directly to the Motherborad. So I guess I did try everything you mentioned , but still nothing Thanks again and certainly thanks for the wish that my daughter finally gets a newer iPhone! |
08-23-2014, 23:41 | #4 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | You have hardware problem battery maybe am not sure Please use search this error already discussed many times Closed Sent using Tapatalk |
