Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 10-21-2014, 06:30   #1 (permalink)
Member: 1860537
Sonork: 1657411
Thanks Meter: 39
iphone 5 imei repair neededs
iphone 5 locked
how to unlock
help me urjent
Old 10-21-2014, 07:45   #2 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
factory unlock from any of the reputed sellers.
Old 10-21-2014, 12:59   #3 (permalink)
Member: 1860537
Sonork: 1657411
Thanks Meter: 39
any tool is not available
this phone is second hend and email protect
i want to use own email
have any solution
i will reset and update by itune
Old 10-23-2014, 13:12   #4 (permalink)
Member: 2278149
How to Unlock iPhone Passcodes
If you have forgotten the passcode on your iPhone, you will have to restore the device.
To restore your iPhone -- which, again, deletes all of your data (songs, photos, videos, apps, and so on) on the iPhone use the following directions. Be absolutely sure that you have backed up the content on your iPhone before restoring it.
iPhone Previously Synchronized with a Mac or PC
If you have previously synchronized your iPhone with iTunes on a Mac or Windows computer, you typically still can backup recent additions to your iPhone by connecting it to the same computer you have used before without having to enter the passcode.
After the backup, you just need to "restore" your iPhone and have the backup copied onto the iPhone with iTunes.
Apple's official instructions to restore an iPhone with iTunes are:
Connect your iPhone to your computer [that you have previously used to sync the device].
In iTunes, select the iPhone in the "Devices" list, then "Summary" at the top of the screen.
If iTunes doesn't automatically synchronize your iPhone, do so manually [and confirm that the sync and backup were successful.]
Click “Check for Update.” iTunes tells you if there is a newer version of the iPhone software available.
Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you [again] backup the iPhone when prompted.
When iOS Setup Assistant asks to set up your iPhone, choose "Restore from iTunes backup."
Select your device in iTunes and choose the most recent backup of your iPhone.
After this process, your iPhone should be restored with the information from its last backup, but it no longer will have the passcode enabled. It would be wise to think carefully before setting another passcode or using the passcode feature again.
Old 10-23-2014, 13:33   #5 (permalink)
string_master's Avatar
Member: 177503
Sonork: 100.1657346
Thanks Meter: 390
have any solution
hello,
i think you are talking about icloud activation lock. search in mail sales section for supplier for that service.
or contact any IMEI server from here
http://forum.gsmhosting.com/vbb/f265/
Page generated in 0.16973 seconds with 8 queries
