08-02-2013, 20:56 | #16 (permalink) |
Freak Poster Join Date: May 2012 Location: dubai Age: 38
Member: 1766383 Status: Offline Sonork: [email protected] Thanks Meter: 4 | i phone 5 restart problem |
09-04-2013, 17:18 | #18 (permalink) |
Junior Member Join Date: Jul 2006
Member: 320826 Status: Offline Thanks Meter: 0 | [QUOTE=sultansaga;9572119]i have same problem unlocked iphone 5 at&t after activate no service always after 2 min searching than no service it is replaced imei i have checked original imei 013431005817699 inside iphone imei 013332002691253 as you can see in photo i have checked its clean imei date time every think updated restored many time any idea how fix ??? how did you replace imei, what software did you use? |
09-06-2013, 11:22 | #19 (permalink) | |
No Life Poster Join Date: Dec 2012
Member: 1847275 Status: Offline Thanks Meter: 635 | [QUOTE=kuljit55;9705855] Quote:
MODEL: iPhone 5 64GB Black IMEI: 013431005817699 SERIAL: DQGK10FAF38W WARRANTY: Applecare Protection Plan ACTIVATION STATUS: YES LAST ACTIVATED SIM: AT&T - United States USA ORIGINAL CARRIER: Retail Unlock Coverage Status: Apple Limited Warranty Coverage End Date: 01/17/14 134 days remaining Purchased In: Canada Estimated Purchase Date: 11/30/12 Replacement devices: Serial ######## IMEI ######## Type Replacement Date DQGK10FAF38W 013431005817699 Active 01/25/13 DNPJQNH8F38W 013332002691253 Original 01/25/13 | |
09-22-2013, 08:47 | #24 (permalink) |
Registered User Join Date: May 2008 Location: india
Member: 763623 Status: Offline Thanks Meter: 37 | put ur handset to airplane mode.. and adjust time to ur orignal country wise and date too.. the go to setting --> gernal---> about---> scrol down screen go to diagnostics & usages select don't send .. then put off airplane mode w8 for 2 min ur problem will be solved this problem occers wen we remove battery from handset that make RTC reset.. try to do as i said BR SAGAR GUPTA |
09-22-2013, 15:32 | #25 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2020462 Status: Offline Thanks Meter: 0 | Hi, i've the same problem And this solution don't runs. My decide is continuos searching. I have jailbreak And ios 6.0.1, baseband 1.01.00. Have anybody any idea for this problem? Thanks. |
11-08-2013, 08:04 | #28 (permalink) |
Junior Member Join Date: Aug 2012 Location: New York, NY, USA
Member: 1801276 Status: Offline Sonork: 100.1647654 Thanks Meter: 7 | Here are the all in one diagrame - guide |
