11-24-2013, 06:09 | #32 (permalink) |
Freak Poster Join Date: May 2012 Location: Turkey Age: 36
Member: 1754273 Status: Offline Thanks Meter: 32 |
iPhone 5 No service/Searching |
12-09-2013, 16:09 | #33 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2070111 Status: Offline Thanks Meter: 0 | i also have an iphone 5 that gets no bars, its blacklisted in a different country and i unlocked it a few days ago, the problem is the first simcard i used when actiated after unlock works, but no other sim, tried 4 different ones, have restored it a number of times, and tried everything else, and now i dont know what to do, so i get the carrier and can connect to the internet from the simcad, but no bars, and cant call or everything, only works with the simcard i used in the firt place, any one have any ideas here? |
12-10-2013, 18:29 | #37 (permalink) |
Member: 2070111 Status: Offline Thanks Meter: 0 | ive tried restoring it at least 10 times, i even open the hole thing and disconnected and connected the antenna, and if i do fieldtest it shows -72 -82 around the same as my own iphone 5, with my sim card i have almost full bars, but with my frieds the owner of the phone i get nothing, we have the same telephone company, and his sim cad works in at lest two diffret mobiles! can you see why im having trouble here? |
01-06-2014, 22:04 | #39 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1776628 Status: Offline Thanks Meter: 0 | Help needed with no service on iPhone 5 after power/volume flex replacement. Have checked all connections and preformed network reset and also tried date time resets. Definite motherboard issue as fault followed motherboard when swapped into another housing and 2nd motherboard able to pick up signal in problem housing. I suspect it my be issue similar to issue on ip4 board that causes no service, fixable by jumping the C93_RF. however I havn't come accross this issue with the ip5 until now If you have solution or can tell me what chip or chips to test and results to expect if faulty or healthy please inbox or preferably send mail to adi AT allphonesmashrepairs DOT com DOT au Regards Adrian |
08-18-2014, 22:05 | #44 (permalink) | |
Insane Poster Join Date: Aug 2006
Member: 331127 Status: Offline Thanks Meter: 6 | Quote:
11-04-2014, 21:24 | #45 (permalink) | |
Crazy Poster Join Date: Jun 2013
Member: 1967720 Status: Offline Thanks Meter: 3 | Have the same issue on 5S where is the location of those chip in the 5S? Quote:
