08-22-2017, 20:52 | #1 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2750223 Status: Offline Thanks Meter: 0 | iphone 5s lcd shield plate removal |
08-31-2017, 16:29 | #2 (permalink) |
Member: 2752792 Status: Offline Thanks Meter: 2 | When you open the screen there are tabs that go along the side of the screen. They simply pull out however be careful since they have the tendency to jerk open. The finger print scanner is connected from the screen to the rest of the phone. It's right by the charging port on the inside. There is a tiny metal cover. Use something sharp to unclip it and the fingerprint scanner wire. After you unclip the finger print scanner simply pull the one side open. The remaining wires are at the top of the screen and go under a metal cover that is held down by 4 screws. My way of doing it is simply open the screen a tiny bit, disconnect the fingerprint scanner, then open the screen the rest of the way. |
The Following User Says Thank You to atanas1850 For This Useful Post: |
