Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 09-22-2015, 16:24   #1 (permalink)
tempb's Avatar
Member: 524229
Thanks Meter: 52
iphone 5s not update baterry percent
please help me my iphone 5s not update battery percent.
The Following User Says Thank You to tempb For This Useful Post:
Old 09-23-2015, 05:25   #2 (permalink)
tempb's Avatar
Member: 524229
Thanks Meter: 52
i can not find any solusion in the internet. please
Old 09-24-2015, 02:52   #3 (permalink)
tempb's Avatar
Member: 524229
Thanks Meter: 52
update i change the battery but same
Old 09-24-2015, 20:39   #4 (permalink)
Member: 2398349
Thanks Meter: 62
change U2 IC I hope it works
Old 11-25-2015, 20:01   #5 (permalink)
Member: 1031328
Thanks Meter: 25
its sure u2 ic change u2 ic then riestore
Old 11-29-2015, 22:06   #6 (permalink)
Member: 267965
Change charging flux
Sent from my MX4 using Tapatalk
Old 12-16-2015, 19:55   #7 (permalink)
Member: 2427042
Thanks Meter: 7
It sound like is the FL11 module on the motherboard. This can get damage easily when disconnecting the battery from the motherboard. Here is pic a for reference.
open and Confirm that this modules are in place.
If they don't you must replace them. This job must be done by a professional, since you can damage the mainboard.
The Following User Says Thank You to amit sagar For This Useful Post:
Old 12-18-2015, 12:52   #8 (permalink)
Cheater -Don't Deal with him-
Member: 2353263
Sonork: +919836422676
Thanks Meter: 28
Cheak FL11 MODULE FOR FAKE CHARGING ON IPHONE
The Following User Says Thank You to nesar786 For This Useful Post:
Old 12-23-2015, 09:13   #9 (permalink)
Member: 950002
Sonork: Laa Elaha Ellallah
Thanks Meter: 119
i think the problem is U2. so, u can change 1st u2 ic then post result,,,
Old 12-23-2015, 09:29   #10 (permalink)
Member: 1031328
Thanks Meter: 25
fake charging & battery discharge sure u2 ic you can change u2 ic solve your problm
Old 12-23-2015, 09:47   #11 (permalink)
mmkhan1000's Avatar
Member: 1187222
Sonork: 9934544800
Thanks Meter: 55
i have same problem in my 5c only show 2% chanrging
i change new battery from market but problem not solve
then i change battery from running set my problem solve
so
its battery problem please change tested battery..
thanks
Old 12-23-2015, 09:51   #12 (permalink)
Member: 2310932
bạn đã làm ok chưa mình cũng bị vậy
Old 12-23-2015, 14:08   #13 (permalink)
Member: 2504808
if i charge with wirless charge it will drain my battery like usb charging !!
Page generated in 0.19935 seconds with 8 queries
