06-13-2019, 16:29 | #2 (permalink) |
Junior Member Join Date: Feb 2014 Location: UK
Member: 2136393 Status: Offline Thanks Meter: 9 | go to imei24 and check if it's got FMI on. If it's off just put in recovery/dfu and restore via itunes or 3u tools |
The Following User Says Thank You to bikervlad For This Useful Post: |
10-12-2019, 11:28 | #4 (permalink) |
Freak Poster Join Date: May 2016 Location: Unlock world Age: 35
Member: 2578723 Status: Offline Thanks Meter: 15 | First things first, make sure you understand the risks of using a shorter passcode. 2) On your iPhone or iPad, launch the Settings app, and go to Touch ID & Passcode (this setting is called Face ID & Passcode on iPhone XS). Enter your current 6-digit passcode. 3) Select the Change Passcode option. Enter your current passcode again. 4) You will now be asked to enter your new passcode. Right above the keypad, you will notice new Passcode Options. Tap on that, then select 4-Digit Numeric Code from the popup menu. |
