04-07-2014, 21:30 | #16 (permalink) |
Major Poster Join Date: Apr 2012
Member: 1744195 Status: Offline Thanks Meter: 4 | BR, A.Y Sent from my iPhone using Tapatalk |
04-08-2014, 08:58 | #17 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Bangalore, India Age: 58
Member: 45873 Status: Offline Thanks Meter: 35 | Dear i have 5 phones with the same problem all happened just while switching frames to gold plated frames all were brand new box pcs none of them were jailbroken professional care has been taken while doing job Doriwala1 you suggested to Remove Cydia All Tweak can this be done for non jailbroken phones stuck on recovery? If so pls give details or links for step by step procedure will like to try. have doubts as even some apps can cause this problem hope it works Regards Riaz |
04-10-2014, 07:51 | #19 (permalink) |
Freak Poster Join Date: May 2012
Member: 1757924 Status: Offline Sonork: 100.1675762 Thanks Meter: 40 | try changing charging flex cable If not helped try changing battery Even not helped finally try to change LCD If didnt solved this means your iphone has dead |
04-11-2014, 02:55 | #22 (permalink) | |
Junior Member Join Date: Aug 2012
Member: 1802673 Status: Offline Sonork: Jimmy Lou Thanks Meter: 1 | Quote:
The Following User Says Thank You to Jimmy Lou For This Useful Post: |
04-24-2014, 10:20 | #26 (permalink) |
No Life Poster Join Date: May 2007 Age: 37
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | my problem solved . i restore all phones with 7.1 because 7.1.1 restore files are corrupt. you can check by click on restore after 80 to 90% downloading file give you error by server . |
04-24-2014, 20:19 | #28 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2171725 Status: Offline Thanks Meter: 1 | Buy an original usb cable (Energizer) it will work. If not, change PC, update/reinstall itunes. Idk what else... I really hope it will work, mine does not charge as well and i buy an original usb cable energizer black type... (But i never recive this error ) |
05-02-2014, 13:53 | #29 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: delhi\kerala\india
Member: 1180290 Status: Offline Sonork: 100.1652502 Thanks Meter: 73 | Quote:
try with new strip,, if still same change u2 | |
The Following 2 Users Say Thank You to shanoopc For This Useful Post: |
