Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-06-2014, 23:04   #1 (permalink)
Member: 2200497
Sonork: MatRebBR
Iphone 5s what to restore and blue screen error 14.
Please someone help me, i have an iphone 5s restore and he the one and blue screen error 14
Old 06-06-2014, 23:19   #2 (permalink)
GSM MOBILES's Avatar
Member: 1624770
Sonork: 1640429
Thanks Meter: 98
use full charged battery and restore it
and let me know
Old 06-07-2014, 12:27   #3 (permalink)
Temporary banned !!
Member: 2200755
Thanks Meter: 2
How to you face this problem? are u assembled your set or you change your battery tell me properly then i will guide you
Old 06-07-2014, 15:34   #4 (permalink)
Member: 2200497
Sonork: MatRebBR
I changed the screen that it was broken, it worked normal again however after it opened to make a repair in sensor he stopped calling and got this error 14 ... when I restore it from a blue screen error and the computer 14. . already tried to restore full battery and the same error.
Old 06-07-2014, 15:54   #5 (permalink)
Temporary banned !!
Member: 2200755
Thanks Meter: 2
Change U2 Ic and then tell me i hope your problem will be solved.. or power off the set and w8 for 72 hours and then on the set..
Old 06-21-2014, 17:07   #6 (permalink)
Member: 351160
Thanks Meter: 40
try to restore him without lcd and try to loosen the screws that have another screw inside... this work for me
Old 07-25-2014, 11:12   #7 (permalink)
Member: 310822
Sonork: ALIAS: POLITEHNICA_1921
Thanks Meter: 9
changed u2 ic and still same problem ... could it be something else ? or should i try again with another u2 ic ? maybe it was bad soldering or something at the first try ... i'we got blue screen after changing boards between 2 phones... now i get error 14 restoring...
Old 07-29-2014, 17:51   #8 (permalink)
Member: 1488472
Thanks Meter: 17
where is u2 IC.................
Old 07-30-2014, 07:54   #9 (permalink)
Super Moderator
mihut's Avatar
Member: 824
Thanks Meter: 25,151
U2 Ic replacement try
Br,
Mihut
The Following User Says Thank You to mihut For This Useful Post:
Old 07-30-2014, 23:14   #10 (permalink)
Member: 1488472
Thanks Meter: 17
I solved the problem so I'm take out LCD. After finishing restore, back LCD, and works great.
Old 08-01-2014, 16:43   #11 (permalink)
Member: 1846541
Thanks Meter: 4
Br,
Mihut
this is one iphone 5, not an iphone 5s..
Old 08-03-2014, 09:30   #12 (permalink)
Member: 2232829
power ic 1000% also dont put u2 ic from iphone5 its not the same
Old 08-03-2014, 09:49   #13 (permalink)
Cheater -Don't Deal with him-
Member: 677681
Sonork: 100.1590886
Thanks Meter: 232
hi,
sometimes i often encounter this blue screen if you change lcd its always connector problem when not properly fitted
Old 12-22-2014, 06:36   #14 (permalink)
Member: 1960721
Thanks Meter: 4
error 14 i am solve 3pc just connect itunes and ios download via itunes and restoe.......
100 succes i am
Old 12-22-2014, 16:53   #15 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
Br,
Mihut
i have iphone 5s error 14 ,this solution not work any other way to solve this prob
pls share pic with me thanks in adv
Page generated in 0.19759 seconds with 9 queries
