01-26-2015, 09:20 | #20 (permalink) |
No Life Poster Join Date: Oct 2008 Location: dubai
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | Iphone 5s stuck in recovery mode even after software complete Hi friends, i have an IPhone 5s , which stuck in recovery mode . *: software is completing *: tried by changing battery and and system connector (lightening)flex, *: tried in different PC *: tried by removing screen and camera *: tried Recboot / tiny umberlla and redsn0w to exit, same still same , the mode is not changing after complete software ... any solution ?? Regards Br |
01-26-2015, 16:44 | #21 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Apple Age: 35
Member: 1918158 Status: Offline Thanks Meter: 177 | Quote:
Don't worry! All you need is ReiBoot. It is a free iPhone reboot software program which allows you to enter and exit from Recovery Mode instantly, easier than learning 3-4 steps manually with iTunes to do so. REIBOOT Step 1: connnect your iphone 5s to PC/Mac. Step 2: Click Exit Recovery Mode Button then you can easily get out the ios 8 update cause stuck in red itunes logo recovery mode. | |
02-18-2015, 09:22 | #22 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1097251 Status: Offline Sonork: monk Thanks Meter: 13 | ??? i changed battery on iphone 6plus,serviced connector and restored without full lcd cables...still stuck on error 4013...any other solution? before closing the thread |
02-18-2015, 09:39 | #23 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | error 4013 and blue screen is related to: 1.- battery 2.- open Lines under the base of the screw on second layer of the board 3.- u2 ic 4.- some other shorted parts generating low voltage 5.- u16 sometimes on restore , low usb power , better use 3.0 usb if is avalible and never use usb hubs , always connect direct usb port |
The Following User Says Thank You to rogerboogie For This Useful Post: |
04-28-2015, 07:51 | #25 (permalink) |
Junior Member Join Date: Sep 2013 Location: India Age: 30
Member: 2032057 Status: Offline Sonork: [email protected] Thanks Meter: 2 | Sir., my i phone 5s i am change my display and center body then my finger lock is not working............ any solution please help........ home button is working but finger lock only not working .......... please help........... thanks in advance................pls.......... |
04-28-2015, 09:15 | #26 (permalink) |
No Life Poster Join Date: Dec 2001 Location: 127.0.0.0.1
Member: 8133 Status: Offline Thanks Meter: 72 | I have a strange issue. Flashed a iphone 5 with screen off and camera off, via DFU mode. Al went through no problem. BUT now when i try to set up phone, and i select country phone screen goes into "connect to itunes" screen! Is it fixable? |
06-05-2015, 02:27 | #29 (permalink) |
No Life Poster Join Date: May 2015 Location: Los Angeles
Member: 2398349 Status: Offline Thanks Meter: 62 | sometimes it happens wen u use a after market part on the phone. open the phone and check what had been changed. change it back with the original part, u'll be just fine. the most common part for this error is the screen or sensor. so restore the phone without screen or sensor to see if its working or not and let me know!! |
