09-04-2019, 14:42 | #32 (permalink) | |
Insane Poster Join Date: Jul 2004 Age: 53
Member: 73434 Status: Offline Thanks Meter: 2 | Quote:
how can we "reset settings" with out access to the settings menu yet bit of a catch 22... or is there a different way to do this ?? | |
09-07-2019, 01:00 | #33 (permalink) |
Freak Poster Join Date: Nov 2005 Location: TUNISIA - BIZERTA
Member: 199254 Status: Offline Thanks Meter: 9 | please i watched the full video but links are dead please give me the link to download backup without icloud firmware for my IPAD2 GSM (2,2) model A1396 thanks |
09-10-2019, 14:18 | #36 (permalink) | |
as once you have done a restore theres no way to get back to menu ? am i following that right ?? | |
09-10-2019, 20:30 | #37 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Romānia
Member: 76629 Status: Offline Thanks Meter: 76 | Quote:
This is used on already activated devices. If you full restore the iPhone with any software, you will need to do the activation wizzard again, so you will be locked up. This method will not help you This is successful when: * you know the user code, * you have full access to the phone menu. This will help you to remove the iCloud user without knowing the iCloud password, even is FMI is ON. You just write this backup to any iPhone 4, 4s, 5, 5c or 5s in the same time when starting up after a "Reset All Settings" from menu. In the moment the software detects the iPhone, you can do a "Restore" to this specific backup, which is the same for all this models. If it cannot be done, there will be no harm to the phone. If the iOs or phone model is not supported, then the backup will not be written, and ERROR 22 will persist. In this case, you will have access to the phone menu like usual. It will not lock you up. The user code will be reset I think, so if you want to use it, you may set it up again. Just make sure you do just a "reset all settings" and leave the content intact. ...press THANKS... :P Last edited by hacktek; 09-10-2019 at 20:40. | |
The Following User Says Thank You to hacktek For This Useful Post: |
