07-29-2015, 16:37 | #1 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1831687 Status: Offline Thanks Meter: 0 | Volume buttons not working after ribbon replacement The mute and power buttons work fine, but the volume buttons aren't working at all. They aren't really clicking and the external buttons seem very loose. Is there a common work-around to solving this? Everything seems to be in place properly. The ribbon is stuck to the side bracket with the holes lined up. |
07-29-2015, 22:26 | #2 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2433461 Status: Offline Thanks Meter: 0 | When you replaced the volume toggle did you check to see if it had 2 metal contacts? I have done a million housing changes and they usually need to be transferred from the original switch hope this helps! |
